EAGLE User Chat (English) package rect and polygons
  • Subscribers 177 subscribers
  • Views 361 views
I made a library part package for a SMT PCB shield can:
http://www.lairdtech.com/pages/products/EMI-BoardLevelShields-PrintedCircuitBoardShields.asp
(BMIS-207)
The pcb layout is 32 rectangles, and I would like these to connect to a
ground polygon if possible but the poly has a clearance and doesn't
hookup to the rectangles for this package.  Is there a way to hook up
package rectangles to a polygon signal, or do I need to use SMD pads in
the libary part to do this?
cheers,
Jamie
    Jamie Morken wrote:
    (BMIS-207)
    cheers,
    Jamie
    Make it a 32 pin component with 16 SMD pads.
    Paul R.
    cheers,
    Jamie
    Paul R.
    How about a 32 pin component with 32 SMD pads.
    I should have let the coffee soak in a little more before posting.
    Paul R.
