EAGLE User Chat (English) Inverted silk
  • Subscribers 178 subscribers
  • Views 399 views
Inverted silk
Hi guys,
Is there any existing idea or ULP to easily make inverted (negative) top
silk layer (or any).
Thanks in advance.
Zoly
    Zoly wrote:
    Hi guys,
    Thanks in advance.
    Zoly
    I export the positive image file - then use a graphics package to invert
    the PCB area and print using MS-Paint (only because it allows you to
    declare the dpi print so you can get the right scale/size) For graphic
    edit I use a geriatric but excellent program - paint shop pro 4... image
    Anton
    Anton
    Thanks for your input, I will try out your the paint shop version.
    In the mean time, I had trouble with MS-paint (I though about this since it
    has the direct inverting function built in), but the fairly large exported
    monocolor BMP file to keep the detailed result is continuously crashing the
    MS-paint on my "not actually low end PC" (core2 duo 6800 Extreme with 4G
    ram, and lots of HDD, fully updated winXP-pro.)
    Also I called the board house, and asked them if they could do the inverted
    silk, they did not say no, but they stated this will create a huge delay
    caused by possible confusion in the CAM department, multi pre-approvals have
    to be presented, involving regional sales guy too ......blah.... (not the
    easy way)
    I am still seeking a possible ULP, that someone might have came across with.
    Best Regards,
    Zoly
    Anton
    easy way)
    Best Regards,
    Zoly
    Hi Zoly,
    Try playing with eagle's export (File - Export - Image) - you can
    specify the DPI there, depending on the detail in your pcb, you may be
    able to get away with a lower DPI - say 200 or so which will reduce your
    file size. From the browse button you can also change the format from
    bmp (which is big) to say PNG or Tiff which have lossless compression.
    Select the layer you want as per printing. (I use eagle ver 4.16r2)
    Remember to set MS-Paint with the same DPI as you export the file with
    .. sounds obvious but ...
    Hope that helps... image
    Kind regards
    Anton
