EAGLE User Chat (English) SOIC-28 and SMT
  • Replies 7 replies
  • Subscribers 180 subscribers
  • Views 1163 views
SOIC-28 and SMT
Hi there,
At the company where I work we have been using Eagle for some time. But
recently, we are making the migration to SMT designs, and I am concerned
that the support for SMT libraries in Eagle seems poor. For example, I need
some straight forward 28pin SOIC packages, but when I look in the IC
packages library there are only PTH components. I checked in the on-line
download library but again nothing.
My conclusion is that Eagle is a really great PTH package, but for SMT I
will need to look elsewhere for a new layout program. Is my observation
accurate, am I being unfair, or have I looked for SOIC-28 packages in the
wrong place?
Cheers,
Ralph.
    Ralph wrote:
    Hi there,
    need some straight forward 28pin SOIC packages, but when I look in the
    IC packages library there are only PTH components. I checked in the
    on-line download library but again nothing.
    Look in ref-packages.lbr. There is a wide variety of SMT packages there.
    Andrew.
    Hi Ralph,
    I think you checked in the wrong place.. at least from my opinion and
    experience Eagle is good in both PTH and SMT packages!
    For your soic28, check the library "ref-packages.lbr" between the
    default libs. And another tip (working for me): if you use "ADD" button
    in the layout editor and you search for a package (ex. SO, SOIC) , it
    shows you the libs where that package is in!
    hope this helps,
    N.
    Ralph wrote:
    Hi there,
    the wrong place?
    Cheers,
    Ralph.
    Ralph wrote:
    Hi there,
    the wrong place?
    Don't conclude so fast image
    For example, there is  SO28W package in the 74xx-us.lbr, that's where
    the typical logic chips are found. But as usual always check packages
    thoroughly against a real footprint and the datasheet.
    Regards, Joerg
  • makenoise
    makenoise over 17 years ago
    Joerg wrote:
    Ralph wrote:
    Hi there,
    But recently, we are making the migration to SMT designs, and I am
    concerned that the support for SMT libraries in Eagle seems poor. For
    example, I need some straight forward 28pin SOIC packages, but when I
    look in the IC packages library there are only PTH components. I
    checked in the on-line download library but again nothing.
    I will need to look elsewhere for a new layout program. Is my
    observation accurate, am I being unfair, or have I looked for SOIC-28
    packages in the wrong place?
    I have been able to find all of the basic SOIC, SOT packages just
    fine... you will have to make your own library parts at times, but it is
    not too time consuming, and obviously quicker then learning a new software.
    Tony
    Anthony Rolando wrote:
    Joerg wrote:
    Ralph wrote:
    Hi there,
    SMT I will need to look elsewhere for a new layout program. Is my
    Yep. Yesterday I needed a SO24W. Took me about two minutes and I found
    it in some other library. Can't complain at all. Actually I found two,
    and one must carefully compare the footprint etc. to the datasheet.
    Don't blindly trust library parts just because they came with the CD, as
    far as I know many are contributed by third parties (users).
    Regards, Joerg
    "gmail" domain blocked because of excessive spam.
    Use another domain or send PM.
    Ralph wrote:
    Hi there,
    the wrong place?
    Cheers,
    Ralph.
    You may also want to take a look at smd-ipc.lbr, which has a good
    selection of SMD footprints.
    -Dave Pollum
  • Richard_H
    Richard_H over 17 years ago
    David Pollum schrieb:
    Ralph wrote:
    Hi there,
    Cheers,
    Ralph.
    -Dave Pollum
    And try ref-packages.lbr.
    It contains all packages that are used in the EAGLE libraries.
    Richard Hammerl
