EAGLE User Chat (English) Changing pin names
  • Subscribers 181 subscribers
  • Views 506 views
Changing pin names
Is there some way to change the pin names that appear in a schematic
after a large part, like a microcontroller, has been added from a
library?
The justification for changing pin names after adding a library part
is this:   Microcontrollers have many multi-purpose pins, and so the
pin names reflect many of those options.  For a particular
application, I would like to simplify the pin names to reflect the
configuration that this particular application will be using.
I know I could make a copy of the library part in my own custom
library and then edit the pin names there, but that seems like a lot
of trouble.  Have I missed something?  Or is this the only way?
Robert Scott
Real-Time Specialties
Ypsilanti, Michigan
  • Richard_H
    Richard_H over 17 years ago
    library?
    Robert Scott
    Ypsilanti, Michigan
    You have to change the Symbol in the library and update it or
    copy the whole device, change the symbol, and use the modified
    one.
    Richard Hammerl
    Former Member over 17 years ago
    If I can live with the pin placement of the existing uC part I change
    the names of the nets attached to the uC to indicate how the pin is
    used.  This is often one of the alternate pin names for the uC.
    I then place a net label near the pin on the uC.  Not exactly what you
    wanted but it works for me.
    library?
    Robert Scott
    Ypsilanti, Michigan
    one.
