EAGLE User Chat (English) How to place topside pad over a bottomside pad
  • Subscribers 179 subscribers
  • Views 373 views
I need to make a new component for an Optek OP124 pill pack diode.  This is
a tiny bullet shaped package designed to be placed in a hole drilled between
the top and bottom sides.  Tthe top side is anode, the bottom side is
cathode.  There must be no plating in the hole.
I can place an SMD pad on the bottom layer and another SMD pad on the top
layer.  I can then place a hole of 1.8mm diameter through the pair of pads.
If I place the pads exactly over one another I cannot name the pads.  If  I
displace them 0.1 mm I can then name the pads.
When I try to route the component, EAGLE shows the air wires going to the
correct places but it never draws the traces and fails to route.  I have
tried AUTO with grids down to 1 thousandth but it never routes.
Any been able to make a component that goes inside the board between solder
and component layers?
Cheers
Brian
  • Richard_H
    Richard_H over 17 years ago
    Hide layer 1 and click onto the SMD on bottom. Can you name it now?
    The problem is that the hole keeps the autorouter from connecting
    the SMDs. The autorouter has to pay attention to the copper/dimension
    value set in Design Rules.
    But you could for example pre-route a short track manually first.
    The autorouter will connect the end of the track then.
    Please keep in mind to export two drill files for the board
    manufacturer. One drill file for drills (layer 44 for pads vias, plated)
    and one for holes (layer 45, non-plated)
    HTH
    Richard Hammerl
    Thank you Richard,
    I found I could manually route the upper and lower traces then autoroute
    the balance.  I have sent the board to CustomPCB in Malaysia WITHOUT the
    two drill files you mention.  I wonder what I will get back??
    Cheers
    Brian
    HTH
    Thank you Richard,
    Cheers
    Brian
    HTH
    On Tue, 25 Nov 2008, BrianT wrote to us saying :
    I have sent the board to CustomPCB in Malaysia WITHOUT the two drill
    files you mention.
    The board house I use don't actually require two separate drill files,
    but they do require that I note which drill numbers are PTH and which
    are not. So far this has worked fine, but I could imagine a potential
    problem if I had the same size hole in both types.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
