EAGLE User Chat (English) Weird offsets of origins in a gerber file.
  • Subscribers 179 subscribers
  • Views 768 views
dukepro
dukepro over 17 years ago
Good afternoon,
My goal is to export all the part origins on an SMT board to ease the
programming of our pick-and-place machine.  Since the P&P machine
accepts gerber imports, I added a section to the CAM processor that
included only the bOrigins layer.
When viewing the origins file overlaid with the bottom copper (using
gerbv), all the origins seem to be offset to the left and below the
actual origin on the board layout screen.
Does anyone have any ideas as to why this offset exists?
    - Chuck
    Chuck Huber wrote:
    Good afternoon,
        - Chuck
    The CAM processor uses the option "pos. Coords." by default. This means
    that the whole layout will be moved near the x and y axis in the positive
    coordinates area. So you will get an offset compared to the coordinates
    shown in the EAGLE Layout Editor. We want to avoid negative values in the
    Gerber data. This would be an absolute show stopper.
    If you switch off "pos. Coords." in the CAM Processor there won't be an
    offset.
    By the way: Did you try our mountsmd.ulp?
    Richard Hammerl
