EAGLE User Chat (English) resistors network
  • Subscribers 177 subscribers
  • Views 643 views
resistors network
Can anybody explain me the difference between RN networks and RNX? I can't
understans which one is bussed network, which one is isolated network...
    The RNX10 appears to be a series string of resistors. I am not sure what
    the RN10 series represents, as it has only one resistor.
    (This is in the "resistor-net.lbr")
    So I share your confusion.
    Maybe best to make your own library part ?
    John G.
    John Giddy schrieb:
    can't understans which one is bussed network, which one is isolated
    network...
    John G.
    Never heard of a bunch of Transistors on a single chip?
    Now a Resistor Network is almost the same. It just means a certain
    amount of Resistors with equal values in a single device.
    There are usually two different RN-circuits: either single resistors or
    resistors with one side tied together.
    In eagle 5-3.x resistor-net.lbr the first two devices CTS742C083 and
    CTS753DRT16 show an example of the inner circuits.
    Yes and there are diodes networks too.... image
    Gruß / regards
    Jörn
    Joern Paschedag wrote:
    network...
    what the RN10 series represents, as it has only one resistor.
    John G.
    I am well aware of what resistor networks usually look like. It is just
    that the schematic for the RN-10 in that library distributed with 4.16
    is very confusing, as it shows only a single resistor connected to pins
    1 and 2, and then pairs of pins with no resistors. "Invoke" comes up
    with a message that there is only one resistor.
    The RNX-10 shows 10 resistors connected to pins in a manner which
    indicates a series string, not a set of resistors with a common connection.
    John G.
    network...
    John G.
    or resistors with one side tied together.
    John G.
    If you do not like the schematic of  RNX-10 why don't you use the G10R
    of resistor-sil.lbr which is exactly the same?
    Gruß / regards
    Jörn
    John Giddy schrieb:
    I can't understans which one is bussed network, which one is
    isolated network...
    John G.
    just that the schematic for the RN-10 in that library distributed with
    4.16 is very confusing, as it shows only a single resistor connected
    to pins 1 and 2, and then pairs of pins with no resistors. "Invoke"
    comes up with a message that there is only one resistor.
    connection.
    John G.
    It wasn't me that wanted to use the RN-10 etc. I was just trying to be
    helpful. The original poster was "Kal".
    John G.
