EAGLE User Chat (English) How to create a SMD pushbutton device with 2 pins and 4 pads?
  • Subscribers 178 subscribers
  • Views 1153 views
I'm relatively new to Eagle and HW design in general. I'm trying to create a
symbol and package for a SMD push button.
The pushbutton symbol has 2 pins, while the package has 4 smd pads. Pads 1
and 2 are electrically connected, and so are pads 3 and 4. When I create
the Eagle device, then the number of pins and pads obviously don't match.
Now I could:
1) leave 2 pads in the package unconnected.
2) generate a symbol with 4 pins and leave 2 pins unconnected in the
schematic.
How can I tell Eagle that two pads are always connected together? It would
be nice if I had only two pins but could route to any of the equivalent pads
and leave the other unconnected, but I cannot think of a way to accomplish
this. Is there a way to do so? Alternatively, what is the 'conventional'
way of handling this in Eagle?
Thomas
    "Thomas Pircher" <tehpeh@gmx.net> wrote in message
    news:og6n36-pdf.ln1@grummel.tty1.net...
    a
    Now I could:
    schematic.
    pads
    Thomas
    Hi Thomas,
    the best way is to create a symbol with four pins and connect all of the to
    the package. If you assign the direction "pas" == passive to them, it will
    cause no DRC error if not all pins are connected. This way leaves you more
    choices. You may come to the point where you want to use the unconnected
    pins. Then you have to go the library again. Better first time right.
    There is no way to tell eagle that pins are connected to each other. This
    must be done in the schematic editor.
    You may take a look at the switch.lbr there are some parts with internal
    connected pins.
    Carsten
    Carsten wrote:
    Hi Thomas,
    connected pins.
    Carsten
    I second this.
    It also gives pissibility to use the switch as jumper.
    For example I feed it the net +5V, and on the other side I name the net +5VB
    to the package. If you assign the direction "pas" == passive to them, it
    will cause no DRC error if not all pins are connected. This way leaves you
    more choices.
    Hi Carsten,
    thanks for the quick reply. Your suggestion makes much sense, it gives the
    most freedom of choice. Now I know also what "pas" stands for. image
    Cheers
    Thomas
