EAGLE User Chat (English) Custom pads...
  • Subscribers 178 subscribers
  • Views 478 views
Custom pads...
Hi there
I need to make a pad for this kind of pin:
http://www.pc-elektronik.dk/images/FSP.JPG
I have made it like this:
http://www.mespilus.dk/pad.gif
Is there a better way to design the pad than this? it is a combination of a
bottom SMD and two pads.
Peter
    Peter Andersen schrieb:
    Hi there
    Peter
    Perhaps the con-faston is something for you.
    Gruß / regards
    Jörn
    Hi there
    combination of a bottom SMD and two pads.
    Peter
    I know the lib, but it is not suiteable for this design.
    Is it not possible to design a custom pad in eagle?
    In the pad i designed above, DRC is complaning about overlap (pad on a SMD)
    but i dont know how else to do it when I want a different shape than the
    given pads.
    Peter
    Former Member over 17 years ago
    Hi there
    Peter
    given pads.
    Peter
    I posted asking the same question. I found a post in some electronics
    forums which claimed you can avoid the DRC errors by moving the SMD pad
    to another layer but it gave no real details. I've searched and search
    but I can't find the link again.I did find this post which indicates it
    is possible:
    I am mounting the power switch on my pcb board. The terminal is in
    rectangular shape but the pad in eagle is round. Is there a way to
    create a custom pad shape?
    Not without a fair bit of trouble. You will have to find a board company
    that will cut the hole out for you. Most people accept the round hole,
    unless it's obviously a bad solution.
    http://www.precma.it/informatica/EAGLE_faq_library.htm
    Hi there
    Peter
    a SMD) but i dont know how else to do it when I want a different
    shape than the given pads.
    Peter
    pad to another layer but it gave no real details. I've searched and
    search but I can't find the link again.I did find this post which
    indicates it is possible:
    company that will cut the hole out for you. Most people accept the
    round hole, unless it's obviously a bad solution.
    Thanx. I think I will stick with what i got so far.
    Peter
    What about miling 2 short slots (using layer 46)? This was often discussed
    earlier in the groups. Talk to your boardhouse. Individual shape of pads is
    long on our wishlist ...
    r
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> wrote in message
    news:gkvppa$88u$1@cheetah.cadsoft.de...
    is long on our wishlist ...
    r
    Yes, this is really needed somewhere down the Eagle versions priorities
    list. I asked about this a while back, and the only solution was to use
    polygons to create the copper layer "drawing" around pads or pins, such as
    might be needed when a custom shaped copper heat sink must be copper
    connected to a pad or pin with or without using a trace (perhaps for
    impedance reasons). The price is having to tell Eagle to ignore the DRC
    "overlap" errors (i.e., "approve" them), but I think the approvals are
    persistent between sessions of a newly loaded existing project unless the
    affected part gets removed and then put back into an existing project.
    Still, I think it best practice if the library designer includes a note in a
    library doc layer, and the library preview itself, indicating which DRC
    "overlap" errors must be approved for a device package used in a project.
    ==> It would be nice if the library itself could somehow keep a designer
    specified list of allowed overlap errors and DRC could look at that library
    list and automatically approve them.
