EAGLE User Chat (English) Design reuse
  • Subscribers 177 subscribers
  • Views 317 views
Design reuse
tech103
tech103 over 16 years ago
I must design several boards which have some piece of design in common.
For example some have the same connectors with IO protections, some
others have the same power supply, some have the same micro-controller.
I would like to create a schematic and route a board for each piece of
design.
Then I would like to take these sub-projects and create a final project
with additional parts and routing.
Is there a way do this with Eagle ?
I would like to know how people are reusing their designs ?
Are you re-routing everything ?
  Jean-Marc
    jml <jmlienher@precitel.com> wrote:
    design.
    It has been discussed before. Scan old postings.
    In short, it can be done, with many workarounds, as usual with eagle.
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
