EAGLE User Chat (English) Re: Enlarging Schematic to Fill Frame
  • Views 422 views
Richard_H
Richard_H over 12 years ago
Am 18.03.2014 11:48, schrieb Jeff Weinberg:
Hi Everyone,
Is there a way to enlarge a schematic to fill a frame?  I have tried
everything I can think of to enlarge a small schematic so that it fits
inside the frame to make it a little easier to read when printed.
Any tricks or advice?
Jeff
http://www.element14.com/community/message/106616
it is not possible to scale the schematic drawing inside the drawing
frame....
Possible options are:
- draw a new drawing frame in the library with a smaller size
- maybe it helps to delete the drawing frame and use the FRAME command
   directly in the schematic editor?
- Use the "area" option in the print dialogue. There you can decide
   about the area to be printed. If you print only a drawing frame
   first and then use this sheet of paper again for the schematic
   you could scale it (sounds a bit complicated, but would be possile...)
Hope this heps.
Richard Hammerl
  • weinbergj
    weinbergj over 12 years ago
    Hello Richard,
    Thanks for the suggestions.  I was able to make a new smaller version of the frame in my own library and that took care of it.
    I also want to take a look at the FRAME command.
    Jeff
