EAGLE User Chat (English) connections
  • Subscribers 189 subscribers
  • Views 700 views
connections
faceter
faceter over 12 years ago
Hi
Still working through the tutorials (CadSoft Eagle Lite).   I have completed a scheme dozens of times but still find that there are quite a number of connections that don't appear to be happening.
When I zoom in on the particular ones that have been highlighted by the checker and move the components a little - sure enough they are not connected.   No amount of effort on my part creates the connection.    The components are on the board but no air wires are shown.
Am I doing something wrong or not doing something.    I'm at a loss, maybe somebody can help me?
Danny
    autodeskguest over 12 years ago in reply to faceter
    Am 18.04.2014 19:35, schrieb Arthur Rodman:
    Hi Joem
    Thanks for that - I have been forcing connection by adding components
    (singly) and then connecting them.   It seems to work but takes forever.
    You say use nets and not wires, sometimes Eagle asks if I wish to use a
    net, generally though it has always been with GND.
    My scheme is finished and the gerber files created  BUT  I wish to make
    my own pcb using the toner transfer method.   Another question  -
    Whish one of the gerber files would I need to use to get the image on to
    a board?   Also, what software package would open that file?
    Sorry if this is too much.
    Regards
    Danny
    http://www.element14.com/community/message/109632
    You don't need  gerber for toner transfer. eagle is wysiwyg. Just select
    your layer, pads and vias and print it on normal paper for a test. If
    that suits you print it on your transfer surface.
    Joern Paschedag
  • dukepro
    dukepro over 12 years ago in reply to faceter
    A good bet would be to use PostScript - PS or PS_INVERT, depending on
    the polarity of your photoresist.
    There are many Postscript viewers - Okular is just one, ghostscript is
    another.  Most printers understand Postscript, so you should be able to
    send it directly to your printer.
    HTH
        - Chuck
  • faceter
    faceter over 12 years ago in reply to autodeskguest
    Hi Joem
    Thanks for that - I have been forcing connection by adding components (singly) and then connecting them.   It seems to work but takes forever.
    You say use nets and not wires, sometimes Eagle asks if I wish to use a net, generally though it has always been with GND.
    My scheme is finished and the gerber files created  BUT  I wish to make my own pcb using the toner transfer method.   Another question  -
    Whish one of the gerber files would I need to use to get the image on to a board?   Also, what software package would open that file?
    Regards
    Danny
    Am 06.04.2014 20:50, schrieb Arthur Rodman:
    Hi
    Danny
    http://www.element14.com/community/message/108456
    Use nets, not wires for connections.
    See that the pins are on grid, set to 100 mils as a standard in schematics.
    Make sure that nets are connected to devices.
    You can check that by moving the devices and all the nets must follow.
    Joern Paschedag
