EAGLE User Chat (English) How to copy Symbol to new one...?
  • Subscribers 180 subscribers
  • Views 1487 views
Former Member over 16 years ago
I want create new symbol to existing Package and this way create new
Device...
After editing an existing symbol SaveAs want save / rename whole lib-file.
Also, how I can copy existing symbol to new one?
Regards, Erkki
    Use Eagle 4.13 Lite
    Device...
    Did you notice that "save as" is in the "file" menu? It seems obvious
    that this is related to the file, as it is very common.
    Open the existing symbol, display all layers, GROUP everything, CUT it,
    create the new symbol, PASTE the existing data there.
    (Manual and HELP provide some information about these commands.)
    Tilmann
    "Tilmann Reh" <user@domain.invalid> skrev i meddelandet
    news:gtbm5v$9i5$1@cheetah.cadsoft.de...
    Ok, thanks... well, I have tried with Group -> Copy -> Paste, but got the
    error message something like "Its nothing to paste"
    Will try again!
    Erkki
    Will try again!
    Erkki
    Copy and Cut are two different commands.
    Paul R.
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
    news:49FA24DA.3010804@arcelectronicsinc.com...
    Will try again!
    Erkki
    Paul R.
    One might think that the 'cut' command should be renamed at some point since
    (as stated in the manual), it is akin to the Windows Copy command; placing a
    copy on the clipboard. Once on the clipboard (and again, this is an Eagle
    clipboard, not the windows clipboard - ctrl C and ctrl V don't work here) it
    can be pasted into different sheets or drawings.
    Eagle's 'copy' command makes only a local copy attached to the cursor -
    which is valid for only the current sheet.
        Oppie
    the Will try again!
    Erkki
    Paul R.
    since (as stated in the manual), it is akin to the Windows Copy command;
    placing a copy on the clipboard. Once on the clipboard (and again, this
    is an Eagle clipboard, not the windows clipboard - ctrl C and ctrl V
    don't work here) it can be pasted into different sheets or drawings.
       Oppie
    There was an explanation as to how cut evolved from cadsoft in one of
    the groups in the last 10 days or so.
    As a side note I think the Eagle program was started around or before
    windows and runs on Linux and Mac.
    But if you think of copy one item or cutting around a group of items.
    Paul R.
