EAGLE User Chat (English) Is is possible to do a 16 position BGA on 4 layer board?
  • Subscribers 179 subscribers
  • Views 460 views
blewis999
blewis999 over 16 years ago
Can someone please advise me on whether it is possible to use a BGA on
a 4 layer board? The center layers ares Vdd and Gnd. So the signal
layers are top and bottom.
The Ball Grid Array is only 4x4 or 16 pins, with a .4mm pitch and ball
of .29mm/.26mm/.23mm (I don't understand this either, is that the max,
avg, min size??).
I have read through the posts, created the device but can't get it to
route for the two center rows. There is a lot of room on the board.
But just looking at the grid I can't really see how to get the auto
router to do this unless there is a way to do a drill hole in the
center of the Ball and plate that through to the opposite side.
But I have no clue on how to get this to work, any advice would be
appreciated. Thank you.
    avg, min size??).
    I assume yes (these are max/spec/min).
    Forget the autorouter and route (at least) this part of the board manually.
    Tilmann
  • blewis999
    On Tue, 12 May 2009 08:03:39 +0200, Tilmann Reh <user@domain.invalid>
    avg, min size??).
    Tilmann
    Ok, thank you. Even routing this manually has some problems. I use a
    6mil trace and the pitch between the balls is .4mm, the max ball is
    .29mm, therefore there is a maximum of .11mm between the ball edges,
    or 2.7mil. How will this work with a 6 mill or even 5mil trace width?
    I also need clearance around the trace?
    I fear you'll need to contact the inner pads by plugged vias.
    (Assume a reasonable pad size of 0.3 mm, which gives you 0.1 mm between
    the pads. You could try to route a 40 µm track inbetween, with 30 µm
    clearance to both pads...)
    Talk to your board house to select a useful (and producable) technology.
    And/or try to avoid such extremely tiny packages...
    Tilmann
