EAGLE User Chat (English) Text not pointing correct
  • Subscribers 187 subscribers
  • Views 345 views
From a DXF i created a scriptfile to place text along a circle.
The text should be readble in the same way. It shows correct in the DXF file
but on the board a section is displayed correct but the other part is a sort
of mirrord.
Is this to be fixed becourse if i do the same by hand it shows at it should
be.
Harry
This is the code:
CHANGE SIZE 5.00;
TEXT R0 '1' (-60,680580 -1,897160);
TEXT R7.5 '2' (-60,395600 -9,873900);
TEXT R15 '3' (-58,576140 -17,679940);
TEXT R22.5 '4' (-55,753360 -25,181700);
TEXT R30 '5' (-51,980000 -32,253420);
TEXT R37.5 '6' (-47,381700 -38,823480);
TEXT R45 '7' (-41,828620 -44,616920);
TEXT R52.5 '8' (-35,633140 -49,702260);
TEXT R60 '9' (-28,826880 -53,935400);
TEXT R67.5 '10' (-22,352520 -59,238540);
TEXT R75 '11' (-14,244620 -61,020160);
TEXT R82.5 '12' (-6,209340 -62,860440);
TEXT R90 '13' (2,062680 -63,140440);
TEXT R97.5 '14' (10,300480 -62,338340);
TEXT R105 '15' (18,364440 -60,472820);
TEXT R112.5 '16' (26,148460 -57,647580);
TEXT R120 '17' (33,416360 -53,667460);
TEXT R127.5 '18' (40,149460 -48,853900);
TEXT R135 '19' (46,196660 -43,202700);
TEXT R142.5 '20' (51,580580 -36,907280);
TEXT R150 '21' (55,399960 -29,536740);
TEXT R157.5 '22' (59,257220 -22,251560);
TEXT R165 '23' (61,668640 -14,333880);
TEXT R172.5 '24' (63,025960 -6,169200);
TEXT R180 '25' (63,311100 2,102820);
TEXT R187.5 '26' (62,596800 10,352840);
TEXT R195 '27' (60,633380 18,403240);
TEXT R202.5 '28' (57,726500 26,152740);
TEXT R210 '29' (53,832980 33,456500);
TEXT R217.5 '30' (49,145520 40,286360);
TEXT R225 '31' (43,014660 45,883240);
TEXT R232.5 '32' (36,976040 51,494600);
TEXT R240 '33' (29,952280 55,873100);
TEXT R247.5 '34' (22,417080 59,297340);
TEXT R255 '35' (14,500740 61,713720);
TEXT R262.5 '36' (6,346940 63,159020);
TEXT R270 '37' (-1,937300 63,346080);
TEXT R277.5 '38' (-10,175100 62,543980);
TEXT R285 '39' (-18,237700 60,673500);
TEXT R292.5 '40' (-26,048020 57,913460);
TEXT R300 '41' (-33,040960 53,440080);
TEXT R307.5 '42' (-40,024040 49,059540);
TEXT R315 '43' (-46,071240 43,408360);
TEXT R322.5 '44' (-51,329040 37,016180);
TEXT R330 '45' (-55,711980 29,994980);
TEXT R337.5 '46' (-59,218380 22,493080);
TEXT R345 '47' (-61,543200 14,539540);
TEXT R352.5 '48' (-62,900520 6,374860);
    "Joern Paschedag" <jpaschedag@t-online.de> schreef in bericht
    news:gve3he$fe7$1@cheetah.cadsoft.de...
    file
    sort
    of mirrord.
    should
    be.
    Harry
    This is the code:
    CHANGE SIZE 5.00;
    I cannot follow you exactly, but why don't you use polar coordinates
    like TEXTxxxxx(Pdistance angle);
    where the distance and the angle is from the 0,0 position.
    (Observe the "P" in front of distance for "polar").
    If you want a different position as the center of your circle set this
    with "Mark" and use "RP" for relative polar, like
    TEXTxxxxx(RPdistance angle);
    text r45 '45' (RP400 45) would read as:
    Rotate text '45' by 45° at a distance of 400 Grid-units and an angle of
    45° from a position set with "Mark".
    Gruß / regards
    Jörn
    If I use
    TEXT RP0 '1' (P53.5 0); in stead of TEXT R0 '1' (-60,680580 -1,897160); the
    text isn't in line with the hole but slightly above.
    I.o.w. the picking point of the text is in the lower left bottom and not in
    the center.
    file
    sort
    of mirrord.
    be.
    Harry
    This is the code:
    CHANGE SIZE 5.00;
    Gruß / regards
    Jörn
