EAGLE User Chat (English) Editing a Schematic Symbol
  • Views 2236 views
6/2/09
I have revivewed this forum and have already found
several helpful hints, so I know that you folks know what you
are doing.
I have oodles of experience with various CADD/Graphics
packages, but I am an absolute novice at using Eagle.
Here's my problem:
Does anyone here know how to edit a schematic symbol?
I have used Eagle (Freeware version)  to create a few microcontroller (MCU)
schematic symbols that I am using in several projects.
I want to create a simplified version of each symbol for
illustrative purposes.
For example, in some simplified schematic cases, I don't want to show
ALL of the MCU pins - just those in use at the time.
Suppose I have a symbol library, "MCU_x.lbr".
How do I delete one or more of the pins and
make a new copy, "MCU_x2.lbr"?
I have reviewed the User manual and all of the Help screens,
with no success.
Any help or pointers to a source of
help will be greatly aappreciated.
Thank you all very much.
Tom Lukers
  • heedaf
    heedaf over 17 years ago
    If you want to make a copy use the group command to draw a box to highlight
    the part, click cut and touch any part of the highlighted part and then
    click paste.
    "Tom Lukers" <tlukers@tx.rr.com> wrote in message
    news:h041o6$v1k$1@cheetah.cadsoft.de...
    6/2/09
    are doing.
    Here's my problem:
    (MCU)
    with no success.
    Tom Lukers
    On Tue, 2 Jun 2009 15:23:35 -0500, "Tom Lukers" <tlukers@tx.rr.com>
    You would be using the library editor.  First make MCU_x2.lbr by
    copying MCU_x.lbr.  Then, from the control panel, open MCU_x2.lbr.
    You are now in the library editor.  In that program, you can edit
    Symbols, Packages, and Devices.  A Device is made up of schematic
    Symbols and PCB Packages.  The editor will not let you delete pins
    from a Symbol as long as that Symbol is still involved with a device.
    You could then delete the Device, then you can edit the Symbol any way
    you want, including deleting pins.  Now you can make a new device in
    which you Add this modified Symbol.  Now save the modified library.
    Now you can Add this new device to any schematic.  It will not connect
    to any PCB layout package, since you didn't add any packages.  It will
    be for schematic display and printing only.
    Robert Scott
    Real-Time Specialties
    Ypsilanti, Michigan
