EAGLE User Chat (English) Power pins not shown
  • Subscribers 187 subscribers
  • Views 729 views
I am using a quad 4+11 opamp which does not show the supply pins ( 4 & 11)
when the 4 sections are added to a schematic.
when I run erc I get these errors
ERROR: Sheet 1/1: no SUPPLY for implicit POWER Pin IC1P V+
ERROR: Sheet 1/1: no SUPPLY for implicit POWER Pin IC1P V-
How do I work with this device to make connections to the Power Pins?
Don S
    Worked like a charm
    Don
    "Robert Pearce" <news@bdt-home.demon.co.uk> wrote in message
    news:K3McjWL$dIRKFw4n@daniel.huneausware.local...
    On Fri, 26 Jun 2009, Paul Romanyszyn wrote to us saying :
    11)  when the 4 sections are added to a schematic.
    Use the built in help and look at invoke.
    You don't actually need "invoke", though it's how you would proceed if you
    want the clarity of the power pins being visible. If all you want is to
    get the power connected, just put V+ and V- symbols (from the "supply"
    library) somewhere on your schematic, and connect them to the real
    supplies.
    Which approach is best depends on how many op-amps and how many different
    supply names your circuit deals with.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    & 11)  when the 4 sections are added to a schematic.
    Pins?
    you want the clarity of the power pins being visible. If all you want is
    to get the power connected, just put V+ and V- symbols (from the
    "supply" library) somewhere on your schematic, and connect them to the
    real supplies.
    different supply names your circuit deals with.
    believe a word.      |
    Don S
    The quick way to find answers is to search the subject of the groups for
    in your case power pin. Asked and answered in userchat 11/19/2005 and in
    support on 5/16/2008 and 11/5/2008. Use the built in help and look at
    invoke.
    And I have not looked FAQ in a while but it may be in that area along
    with other tidbits you will need.
    Paul R.
