EAGLE User Chat (English) Part on board does not match library
  • Subscribers 187 subscribers
  • Views 461 views
Using Eagle 5.5.0 licensed.  There is a through-hole connector in the library.
  Drill size is set then pad diameter adjusted to accommodate 0.18mm minimum
track spacing.  In the library it is fine but once on the board the pad
diameter becomes larger and violates the minimum track spacing.  If a change
is made in the library (e.g. use offset pads instead of square), track spacing
is fine in the library but the pads are again larger when the library is
updated on the board.  The only fix is to specify a smaller drill, marginal at
best.  Any suggestions?
  • Richard_H
    Richard_H over 17 years ago
    library.  Drill size is set then pad diameter adjusted to accommodate
    0.18mm minimum track spacing.  In the library it is fine but once on the
    board the pad diameter becomes larger and violates the minimum track
    spacing.  If a change is made in the library (e.g. use offset pads
    instead of square), track spacing is fine in the library but the pads
    are again larger when the library is updated on the board.  The only fix
    is to specify a smaller drill, marginal at best.  Any suggestions?
    See also  http://www.cadsoft.de/faq.htm.en#06012601
    Richard Hammerl
    i think you have encountered the "restring" problem, look up restring in
    the DRC settings and help files.
