EAGLE User Chat (English) output to HP 7475A plotter
  • Subscribers 187 subscribers
  • Views 578 views
I am interested in outputting layouts directly to copper using an HP 7475A
poltter.
I have done this successfully with a really old DOS version of AutoCad (v.9)
and was thrilled with results.
I have located a driver which supposedly works in XP but the 7475A does not
accept output from Eagle.
I have tested the communications using ACAD and all is good.
I understand that plotters are NOT printers.
My question is does Eagle provide a way to output in a form the plotter will
understand?
or 2. is there a way to convert an eagle layout to a form which can be
imported into ACAD so I can plot from there?
As a hobbyist, the ability to make "one-off" boards by plotting directly to
copper saves a ton of work and produces a very high quality result
(depending on the 'Sharpies' used)
Thanks for your help
Don Soucy
    Solution in Hand!
    Thanks to those who took the time to try and answer my question.
    I found the solution in a little program I downloaded about a week ago, but
    never put 2 & 2 together.
    The program is called Terminal V.19b by Bray.
    It allows full 'tweaking' of all Com Port parameters and has a 'send file'
    function.
    It takes some editting to get the HPGL file generated by Eagle Cam to run
    without plotter errors, but I've made magnificent strides today.
    I will eventually create a detailed description of the process and post a
    link to it here for anyone else who wants to use an old HP 7475A plotter to
    plot directly to copper.
    Don Soucy
    "Harry H. Arends" <info@time-tech.eu> wrote in message
    news:h2g5v8$2ua$1@cheetah.cadsoft.de...
    Question: can you plot something from a other program such as WORD?
    Or try to save the Eagle output to a file and then send it to the plotter
    by DOS in a DOS-Box using something like C:\Copy Filename.prn LPT1: /b
    (the b sends it as a Binary file)
    That worked for me when using Microstation to send drawing to a HP printer
    when Bentley had not yet drivers implemented.
    Harry
    "Don Soucy" <editor@primegood.com> schreef in bericht
    news:h2g06u$cri$1@cheetah.cadsoft.de...
    poltter.
    (v.9) and was thrilled with results.
    not accept output from Eagle.
    will understand?
    to copper saves a ton of work and produces a very high quality result
    Don Soucy
    Or try to save the Eagle output to a file and then send it to the plotter by
    DOS in a DOS-Box using something like C:\Copy Filename.prn LPT1: /b (the b
    Harry
    poltter.
    will understand?
    Don Soucy
