EAGLE User Chat (English) New free Altium version coming
  • Replies 26 replies
  • Subscribers 193 subscribers
  • Views 3154 views
IanJ
IanJ over 12 years ago
Hi all,
Not sure if has been discussed here already (I did look) but Altium have decided to join the FREE pcb design bandwagon in direct competition to Eagle PCB.
There's a thread over at the EEVblog, goto page 8 and you'll see Dave has posted a good amount of detail.
I actually think this is good news for Eagle PCB users as hopefully CadSoft will respond and maybe push harder at bringing some long wanted functionality to Eagle. Can we look forward to big changes to Eagle in Version 8......?
http://www.eevblog.com/forum/altium/free-altium-is-coming/
Page 8:-
http://www.eevblog.com/forum/altium/free-altium-is-coming/105/
Ian.
    autodeskguest over 11 years ago in reply to autodeskguest
    On 10/23/2014 9:17 PM, Andrew Kohlsmith wrote:
    Jorge, thank you very much for such a rational and calm answer. I'm very
    happy that there are Cadsoft employees like you on this newsgroup.
    Thank you Andrew, this made my day.
    • Library manager (make this work over a network socket so I can write
    my own library server software!)
    I've seen some companies implement SQL databases for components and
    inventory. Do you mean something like this?
    Kind of, but I do not want to get limited to someone's idea of the idea
    SQL database. A full collaborative library backed with git or online
    would be possible if the librarian protocol were documented and operated
    over a network socket. Pushing libraries into SQL databases isn't even
    close to what I have in mind.
    Most times the librarian would run on the same computer as the schematic
    editor/layout, but by using a network socket much magic could be
    implemented. I have a number of ideas on this that I'd be happy to share
    with Eagle in more detail. It's a pretty large request, but you've got
    the beginnings of it with the DesignLink idea from v5.
    Technically this is also possible since the addition of the system()
    function to the ULP language. It essentially gives EAGLE terminal access
    on your machine, so you can have EAGLE do anything that you can do from
    a terminal. Very powerful.
    Agreed; this is a hack for something such as a librarian though. It is
    one method that could be made to work, but a proper and documented API
    would certainly be a lot better.
    It would take a lot of work to make an API for functionality like that,
    if its something you need immediately, I think the system() function can
    do what you want.
    The v7 update so far is a cruel joke, and a slap in the face to your
    loyal users.
    Taking it a little too hard there. V7 isn't done, and there's some big
    things coming in the next two releases to make up for all of the time
    lost with an "improved" licensing mechanism we had to can less than a
    month after the release of V7. You won't have to wait for V8.
    Yes, it was over the top. I do apologize for my hyperbole. I am very
    passionate about my tools, and Eagle is a tool that I use almost every
    day. (I am also very passionate about my morning coffee.) There are so
    many things that need to be addressed in Eagle that when I saw what was
    considered "major revision change, worthy of charging everyone $400" ...
    well the response is already well documented. image
    I'm hopeful about the upcoming releases though and I think you can be
    too, different people have different features that are important to
    them but the upcoming releases should help V7's hemoglobin levels.
    Some visibility into what is being worked on, what the plan is for v7
    and what will absolutely be pushed off until v8 would go a long way in
    alleviating the frustration. Right now we don't have any idea of what we
    can expect to receive for our upgrade fees, and what was presented in
    7.0 and 7.1 is simply not worth the money.
    See the thread by Richard Hammerl on the support forum, that will give
    you an idea of what we're looking into and the opportunity to place your
    2 cents.
    A bug tracker (not a newsgroup, but a bug tracker where issue #s could
    be tracked, updates given, etc.) would also go a long way to help.
    We have a bug tracker internally. That reason we don't make it public is
    that we lack the man power to keep it clean. I can only imagine, how
    many "My pads look different on the board versus the library" bug
    reports we would get and have to clean up. So currently, the support
    staff (Richard, Alfred and yours truly) report bugs and feedback.
    hth,
    Jorge Garcia
    very happy that there are Cadsoft employees like you on this newsgroup.
    On 2014-10-23 18:30:52 +0000, Jorge Garcia said:
    • A "board flip" mode so I can see what the bottom of the board will
    look like easily
    The mirror-board.ulp achieves the visual effect, but some users dislike
    that fact that it's actually moving stuff around to achieve it.
    Indeed; it's a hack, and one which I do use on occasion. Being able to
    quickly flip back and forth with a command and a hotkey would be very
    welcome. (I know you can execute scripts on hotkey, but again, using
    such a hack just to see the board is a bit disconcerting, not to
    mention time consuming for complex boards).
    • "Live" or "hot" DRC during routing
    +1 but with the option to disable. Sometimes you have to break the rules image.
    This goes without saying. Almost EVERY option and feature should be
    configurable, and every command should be hot-key assignable and
    accessible from EagleScript.
    • An SMT pad editor that lets me define arbitrary polygons instead of
    rectangles only
    This can already be achieved using the aribitrary pad shapes feature
    implemented in V6. What we are missing now is a nicer way to deal with
    slotted drills.
    I did not know this! It's right there in the help text though. Wow,
    this would have saved me some headaches a few months ago. Thank you!
    • Configurable default text size/ratio for labels/nets
    See the eagle.scr file, this allows you to setup defaults on an editor
    by editor basis.
    Hm, I'd played with this but was not able to achieve the results I
    wanted. I'll revisit this and start a new thread in support if I still
    can't figure it out.
    operated over a network socket. Pushing libraries into SQL databases
    isn't even close to what I have in mind.
    schematic editor/layout, but by using a network socket much magic could
    be implemented. I have a number of ideas on this that I'd be happy to
    share with Eagle in more detail. It's a pretty large request, but
    you've got the beginnings of it with the DesignLink idea from v5.
    API would certainly be a lot better.
    loyal users.
    ... well the response is already well documented. image
    we can expect to receive for our upgrade fees, and what was presented
    in 7.0 and 7.1 is simply not worth the money.
    Thank you again for your calm demeanor. The beer is on me if we ever meet.
    -A.
    On 23/10/14 19:30, Jorge Garcia wrote:
    I thought it was a half-hearted marketing ploy since it was an easy
    thing to squeeze in at the last minute image.
    You said it image
    I figure many users familiar
    with EAGLE have reverted back to the old icons.
    Yes, because they worked
    For the most part I like
    the new icons,
    For the most part I dislike them less than most of the post-Windows-8
    icon/GUI work-overs that many applications have had. The Microsoft ones
    in particular are catastrophically crap. Please, Cadsoft, if you must
    "update" such things, do keep up the practice of allowing us to revert
    to the original nicely designed Eagle look-and-feel that works so much
    better.
    On 10/22/2014 3:02 PM, Andrew Kohlsmith wrote:
    On 2014-09-18 22:22:02 +0000, Jorge Garcia said:
    You're the first person I've ever heard say Cadsoft is ahead of
    Altium, so I appreciate that.
    I've been an Eagle fan for over 10 years. v7 is the first time I've
    actually really started looking at alternatives.
    The v7 feature list is aenemic. You've given the icons a face lift and
    added hierarchial schematics, and done some (I hear) great work on the
    autorouter, a feature I have used once in that decade. image
    I'm very interested in understanding what you consider a WOW factor.
    That phrase means different things to different people, what does it
    mean to you?
    Here's my short list:
    • Proper/real alpha blending of layers in the board editor
    • Removing the old "DOS-era" 16-colour limitation for layers
    • Allowing layers to be visually stacked in an arbitrary order (easily
    changable with hotkeys)
    look like easily
    • Displaying the net names on the tracks
    +1
    • Push and Shove routing (NOT as part of an auto-router license)
    • Replacing (or augmenting) EagleScript with Python or Lua
    +1 but with the option to disable. Sometimes you have to break the rules ;).
    • More manageable/configurable meander and live update for matched pair
    length
    +1
    • Live display of track length during route or with hover-over
    rectangles only
    slotted drills.
    by editor basis.
    • Smarter cross reference display of off-sheet nets
    • FULL keyboard acceleration (make every possible action able to be
    hot-keyed, not just a few)
    • Multi-clipboard buffers
    • Proper icon and menu text zoom/DPI support for high-resolution displays
    • Gerbmerge (http://sourceforge.net/projects/gerbmerge/) integration for
    panelization
    ... this is the short list. There is no end of the features that you
    should be adding to Eagle to just keep up with the competition.
    I love Eagle. I want it to succeed. I love the "live" forward/back
    annotation. I love that it's multi-platform. I love that you (now as
    of v6) have XML file formats. I love your licensing. I love your price.
    I hate your quality control, I hate the lethargic approach to what many
    consider basic features for any professional EDA package, and I hate
    how you generally dump support for the previous version the moment a new
    major release is made.
    loyal users.
      I truly do hope that this is corrected. I'm really not sure
    that I will wait for v8, even if that means running Altium in a VM or
    jumping ship to KiCad, which is figuratively breathing down your neck in
    terms of features. You have no idea how much it hurts to say such a
    thing, but that is how bad this has gotten.
    An icon refresh should have been the last thing on your todo list for
    a major point release. What were you thinking?
    thing to squeeze in at the last minute :). I figure many users familiar
    with EAGLE have reverted back to the old icons. For the most part I like
    the new icons, I think they could use some more color and the ones for
    the control panel still need some work. We're human, we make mistakes
    and do our best to learn from them and improve our product for our
    customers.
    too, different people have different features that are important to them
    hth,
    Jorge Garcia
    autodeskguest over 11 years ago in reply to e14 Contributor
    Eagle will be better after implementation this things (by my opinion):
    1. part editor in PCB mode (change pad shape, silkscreen,...)
    2. better library manager:
    - multi select of devices/symbols/package and copy/move/remove to new
    devices/library...
    This is being worked on.
    - edit of multiple devices properties and attributes in one window
    (Excel style) - ex: change custom attribute for all devices in library
    - possibility of create device variants with more symbol pins than have
    package pad. Ex: http://www.nxp.com/documents/data_sheet/PCA9633.pdf -
    Pin A1 - check packge TSSOP8 and TSSOP10 - this can be one device but
    two variant
    3. improve schematic:
    - buses and his naming is horrible! Is it problem make dialog with list
    of all schematic net and selecting of them by mouse clicks?
    This could slow down your workflow, having to look through lists of nets
    just to pick the members of a bus. It could be more intuitive than it is
    now, but this is using an elephant gun to kill a mosquito.Imagine
    designs have 1000's of nets.
    - Smash - remove this decelerate function
    This function makes the text in the component selectable for individual
    modifications. I think that's important for fine control of the
    schematic, what would be the alternative.
    4. Do you know "Inspector" in Altium? - Absolutely great function! In
    cooperative with filter selection is my favorite.
    5. Ticket system for new feature request for altium users - easy way how
    to implement new function into altium - also great thing (missing in
    cadsoft).
    See suggestions forum.
    hth,
    Jorge Garcia
    michaelkellett over 11 years ago in reply to autodeskguest
    Ciruitmaker - free as in "there is no such thing as a free lunch".
    You would have to be completely mad !
    autodeskguest over 11 years ago in reply to tekmeister
    On 2014-10-23 10:56:56 +0000, Jeremy Kuek said:
    no-one's mentioned it in this thread yet, but the "free Altium" was
    formally announced a few weeks back. It will be called CircuitMaker
    (http://circuitmaker.com/)
    Cloud based EDA. No thank you.
    It absolutely looks great, but I'm not trusting my workflow to
    something that I can't nail down in a VM and use forever if I have to.
    -A.
    e14 Contributor over 11 years ago in reply to tekmeister
    Yes, I know this new SW, but CircuitMaker will be Cloud based :-(
    But, I hear about Altium Designer new licence politics. If i have true, Altium will be derived into few new variants as standart, proffesional, etc
    Of course, price will be also derived based on variant.
    But, maybe I have misinform.
    We will see...
  • tekmeister
    tekmeister over 11 years ago in reply to e14 Contributor
    FYI,
    no-one's mentioned it in this thread yet, but the "free Altium" was formally announced a few weeks back. It will be called CircuitMaker
    I've registered to try it, but haven't received any emails yet.
    e14 Contributor over 11 years ago in reply to autodeskguest
    I'm absolute agree with you!
    I use Altium(14)/Eagle (6) everyday (+/-).
    I know design Schema/PCB In Altium  more comfortable, faultlessly and faster than Eagle, but  - price....
    - multi select of devices/symbols/package and copy/move/remove to new devices/library...
    - edit of multiple devices properties and attributes in one window (Excel style) - ex: change custom attribute for all devices in library
    - possibility of create device variants with more symbol pins than have package pad. Ex: http://www.nxp.com/documents/data_sheet/PCA9633.pdf - Pin A1 - check packge TSSOP8 and TSSOP10 - this can be one device but two variant
    - buses and his naming is horrible! Is it problem make dialog with list of all schematic net and selecting of them by mouse clicks?
    4. Do you know "Inspector" in Altium? - Absolutely great function! In cooperative with filter selection is my favorite.
    5. Ticket system for new feature request for altium users - easy way how to implement new function into altium - also great thing (missing in cadsoft).
    .. and more and more.
    I'm waiting for new Altium price/licence/version system (will be released next year - I hope). If will be good - bye bye Eagle....
