EAGLE User Chat (English) Recommended Practice for handling drill data?
  • Views 775 views
jameslittlefield
jameslittlefield over 16 years ago
Using Eagle 5.2.0 Professional and recently managed to create a
situation where the symbols shown in the drill layer were inconsistent
with the same symbols shown in the drill legend.   After experimenting a
bit with Options->Set->Drill->Set and then editing the drill order
manually,  I was eventually able to get things back in sync.
It does appear however that the drill table extracted from a board does
not (always) list the drills in the same order as for drillegend.ulp,
drill-legend.ulp, and drillcfg.ulp.    Is there a recommended sequence
of steps for getting consistent results among all these ulps?
Jim
    autodeskguest over 16 years ago in reply to autodeskguest
    bump
    As noted, working on dozens of different boards with different drill sets,
    the script-generated table does not always match the symbols; because the
    options-drill-set command does not properly extract drill diameters in
    increasing order.
    Is there ANY way to allow a .ULP to modify the options-set-drill table?
    thanks,
    ..dane
    "Jim Littlefield" <jameslittlefield@verizon.net> wrote in message
    news:h9861u$a9d$2@cheetah.cadsoft.de...
    Ing. J.M. Rafetseder wrote:
    There is an ulp "drillegend" by A. Zaffran/C. Bohrer from 30.07.08
    (download -> ulp) which works automatically & places a drill-table on
    layer 144. No need to to run the set drill command.  Works fine with V4.x
    & V5.x
    r
    I understand/use this ulp.   The issue is that the actual drill symbols in
    layer 144 don't always map correctly.    As noted in my original post (and
    Bob Johnson's follow up) it appears that the ulp does not assign symbols
    and drill sizes in the same order as Options->drills->set-Drills so you
    can wind up w/ inconsistent data.
    jiml
    autodeskguest over 16 years ago in reply to e14 Contributor
    V4.x & V5.x
    r
    in layer 144 don't always map correctly.    As noted in my original post
    (and Bob Johnson's follow up) it appears that the ulp does not assign
    symbols and drill sizes in the same order as Options->drills->set-Drills
    so you can wind up w/ inconsistent data.
    jiml
    Jim
    I bounce back and forth between projects all the time, and this is always an
    issue when I do that. Maybe there's an easier way, but I haven't found it.
    I just have it as an item on my fabsteps checklist to always check
    Options->Set->Drill after I run drilegend.ulp, and manually set the drill
    order to match the table generated by the ULP before printing a fab
    drawing. If there's a better approach, I'd love to hear about it too.
    Ok...thanks for the info....thought I was missing something important.
       I guess until know I have been fortunate that things happened to
    workout  OK with manual intervention!
    Jim
    (download -> ulp) which works automatically & places a drill-table on layer
    144. No need to to run the set drill command.  Works fine with V4.x & V5.x
    r
    Jim
