EAGLE User Chat (English) Gerber for selected area of board
  • Subscribers 178 subscribers
  • Views 389 views
Halloo All
Is it possible to generate a gerber file for a sub-section of a board?
I have a schematic containing components that are not on the main pcb,
such as LCD display, keyboard etc.  On my board layout I have simply
moved these components outside the outline of the board I wish to be
produced then run the autorouter.  Fine so far.  For the gerbers I want
to send to the manufacturer I only want the layout lying inside my
board outline with the outlying parts removed/masked.  Is this
possible?
I see there are parameters like   Offset="0.0mil 0.0mil" and
Page="12000.0mil 8000.0mil" in the gerb274x.cam file so I assume these
manipulate plot area in some way.
Mike E
    Once again, my favorite problem...wouldn't it be nice to mark those
    parts as "off-board"?
    Of course, some will now chime in that they shouldn't be in your
    schematic in the first place, or that you should make new packageless
    parts from the symbols and use those...because that is the most
    convenient way to go image Or perhaps you will become so confused that your
    display is off-board that you will misinterpret the lack of warnings or
    the loss of forward/backward annotation, and gosh, it's just not worth
    it! Let's just keep struggling on the old way.
    Mmm, packageless parts eh?
    The reason they are on the schematic in the first place is that I'm also
    developing the software and being able to have a single sheet of paper
    showing what all the data lines connect to is very convenient.  I could and
    likely will eventually, write a proper specification document with tables
    and diagrams and explanations of what does what then bind that into a
    booklet.  I guess I'll have to copy and paste the off board components to a
    new set of schematics just leaving the relevant PCB related bits with lots
    of port symbols.  Then take screen shots of each set of schematics and glue
    them back together again in Gimp. image  Or Sellotape. (Other tapes are
    available). I guess I was hoping for some command line or config. file magic
    to restrict the area that was 'seen' by the gerber generation tool.
    Cheers Gary .
    Yeah, it is frequently suggested that for parts not actually on the
    board, just in the schematic for documentation, that you draw only the
    symbols and place these in the schematic, then use sham wires to show
    the connections, I would guess in a special non net layer.
    I prefer normal parts that can be marked "off-board" or a "null package"
    ( that is blank and matches all pin configurations ) that allows one to
    place the part in the schematic normally but leaves it off the board.
    The connections to it are also ignored by the board editor.
    Somewhere, of course, there has to be a physical interface like a
    connector or solder hole, but the part behaves in the schematic and
    simply documents the circuit for the reasons you have outlined.
    This suggestion is surprisingly controversial.
