EAGLE User Chat (English) Programmatically Rename Nets
  • Subscribers 177 subscribers
  • Views 603 views
I'm trying to write a ULP that renames nets programmatically.  I've
tried using the NAME command, e.g.
NAME N$8 XD4
But this gives me an unknown part error.  If I type in NAME and then
click the wire that corresponds to that net, it allows me to rename it.
  Is there some way that I can rename a net by its name?
Dave
    "David Brigada" <brigad@rpi.edu> wrote in message
    news:h9vrn6$udr$1@cheetah.cadsoft.de...
    I'm trying to write a ULP that renames nets programmatically.  I've tried
    NAME N$8 XD4
    But this gives me an unknown part error.  If I type in NAME and then click
    the wire that corresponds to that net, it allows me to rename it. Is there
    Dave
    I guess you need to enter coordinates for one of the wire ends like this:
    name "newname" (x y);
    But beware of these issues:
    Issue 1)
    If you do this on schematic and have a split net, you will get a requester
    up asking if you want to do two or three of the following options:
    -This segment
    -Every segment on this sheet
    -All segments on all sheets
    You are not allowed to choose default action in scripts (Ive posted that
    request on eagle.suggest.eng a few times)
    Issue 2)
    If you do this on board, you also need to do polygons, and you will get
    similar requests.
