EAGLE User Chat (English) Auto routing all pads on one level
  • Subscribers 179 subscribers
  • Views 260 views
Former Member over 16 years ago
Eagle 5.6 light.
Is it possible to route all the pads on one layer and only use the other
layer with vias. I do this when I build my proto boards as it helps to not
have to solder top pads on thru hole pins (electrolytic caps for example)
Rob
    you can use the restrict layers to stop connections from happening. see
    in the demo, the "single layer" board for instance.
