EAGLE User Chat (English) creating "holes" in polygons?
  • Subscribers 187 subscribers
  • Views 1852 views
I have a polygon on a layer for a ground net. I'd like to create a
"hole" in this polygon so there is no ground fill under part of a
particular component.
I know about rank and isolate, but I'm not able to achieve the desired hole.
I'd really prefer not to have to use split and create a complex
irregular polygon shape, but at this point I think this may be my only
option.
Andrew
    autodeskguest over 11 years ago in reply to autodeskguest
    On 2014-10-24 07:07:31 +0000, warrenbrayshaw said:
    Simply use the restrict layers 41  and 42 .
    Draw the shape, be it a rectangle, polygon, circle or wire in the layer
    that  relates to the top or bottom layers and the polygon fill will not
    fill that area. You can do each time on the board or do it in the
    library package so its always done when you use that part.
    I think this works well for outer layers, and I make good use of the
    restrict layers (and keepouts too), but I don't think this works very
    well for inner layers.
    Lorenz suggested using polygon fill type "cutout" which seems to be the
    "official" way of supporting cutouts.
    -A.
    On 2014-10-24 05:41:57 +0000, Lorenz said:
    "help polygon" - look for "polygon cutouts" at the bottom
    sigh
    Thank you, Lorenz. I can't believe I missed that.
    -A.
    hole.
    HTH
    Warren
    option.
    Lorenz
