EAGLE User Chat (English) How do I copy/paste a layout from board editor to multiple copies of that layout?
  • Subscribers 189 subscribers
  • Views 652 views
I have a project that uses a cluster of LED's and associated components to
run those LED's.  I have placed the parts and routed the traces, and I
have a power and ground pad.
Now I want to take that entire layout and copy and paste it in a grid
pattern on my board, so that in the end I will have a 10 x 10 grid of
these smaller layouts.
I know Eagle has the panelize script but I don't think that will work,
because the power and ground pad of each cluster should all be connected
together.
If I lay it all out in the schematic editor, it is just too much work to
individually place a few thousand components, when all I want to do is
place them once, and copy-paste them into 99 other locations.
I tried closing the schematic, which lets me copy/paste them in the board
editor... but then I get an error that my PCB/schematic are not
consistent.  I tried having ONLY the replicated components on the board -
then closed the schematic, then pasted 99 copies in the board editor, then
opened the schematic, then copy-pasted 99 copies in the schematic editor,
but it still says the board and schematic are not consistent (because of
the component names, I think).
How do I most easily achieve this?
MR
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
  • Morosh
    Morosh over 16 years ago
    "Mike R" <mwbhts.spam@gmail.com> wrote in message
    news:op.u4kz71y4t20s7x@atmel-prog.ecagroup.com...
    together.
    MR
    Eagle home page --> Download --> ULPs --> duplicating_v44.zip
    M
    This was discussed earlier, the trick is to rename evrey net in the sch
    with a unique name (no N$xx). Then you must close the sch, group, cut, paste
    & arrange your brd's. Then close your brd & do the same with your sch's. At
    last open both & correct GND & VCC, work thru the error-list. Now you should
    have B-F-C again. Hint: do this with a copy of your original, so if anything
    will crash, the original is not gone.
    r
