I'm designing a circuit that requires a long thin slot (6x1 mm) in a pad for
a relay terminal, has anyone come up with a solution for this?
Rob
Rob
Morten Leikvoll wrote on Mon, 14 December 2009 04:04
If you use milling layer on plated holes,
Note that whether internally routed slots are plated depends on the fab
process, and you will get different results with different manufacturers or
will have to pay extra to get what you want.
Quote:
take care if you use fill's or
power layers somewhere between upper and lower layer. If you have that,
either make sure it doesnt fill under the plating, or tell the
manufacturer
to make sure the plating doesnt make shorts.
Or just set up the DRC rules properly in the first place so that there is
clearance between planes and board edges.
"Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
news:hg37k0$d5v$1@cheetah.cadsoft.de...
Rob wrote:
for a relay terminal, has anyone come up with a solution for this?
Rob
Search for slot in user and in support for detailed threads on the
subject. The short answer. Use the milling layer and contact your board
house.
Paul R.
A warning to this issue if the hole is plated: (a useful warning can not be
repeated too often)
If you use milling layer on plated holes, take care if you use fill's or
either make sure it doesnt fill under the plating, or tell the manufacturer
By always giving the manufacturer a netlist with test points (like
ipc-d-356), the manufacturer will find problems like that before he starts
manufacturing.
Rob wrote:
Rob
house.
Paul R.
