EAGLE User Chat (English) Change restring for one specific component
  • Subscribers 187 subscribers
  • Views 507 views
I had a problem with some of pads not printing properly and wanted to
change the pad size.  Someone pointed to DRC, restring and I was able to
increase the size of the pad which worked wonderfully; actually too well
since the pads of a TO228 are now seemingly too close together.  Is
there a way of either excluding pads from changing sizes or to select
only those pads that you want to changes sizes?  Thanks
Carroll
    cjolly wrote on Sun, 13 December 2009 21:34
    to
    well
    Exactly.  Changing library package details afterwards is dangerous.  The
    right way to do this is to update the library.
    If the pads are too small for the hole that the part needs, then that is a
    error in the package and should be fixed.  If you just want larger rings
    around pads in a particular instance, then you should create a new package
    with the larger pads and add that to the same device.
    In general, wanting to change such things at the board level usually means
    you're not thinking something thru correctly.
    Carroll
    You will have to change the part in the lib and then do an update. There
    may be a auto size property for each pad that has to be turned off so
    you can change the pad diameter.
    Once you get the learning curve down on lib editing and updating is
    would only take a minute or 2 to make that type of change to a part.
    Paul R.
