EAGLE User Chat (English) DRC Settings for Advanced Circuits
  • Subscribers 187 subscribers
  • Views 585 views
Hello everyone,
I have a customer who would like to use Advanced Circuits to manufacture
their board(s).  However, AC requires 10mil clearance from a drill to any
other feature on an internal layer.  From what I understand, this is the
edge of the drill, not the center.
I can't figure out a way to account for this parameter with the DRC.  Can
anyone come up with a creative solution other than writing a ULP to detect
this?  I know I ran into it before and just went elsewhere (yes Terri, to
Sunstone).
Cheers,
James.
email:  james@eaglecentral.ca
web: http://www.eaglecentral.ca
Specialising in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
    "James Morrison" <james@eaglecentral.ca> wrote in message
    news:him1m8$7nj$1@cheetah.cadsoft.de...
    Sunstone).
    The different signals is easy I guess? The same-net is worse. They can get
    down to infinite small, no matter what you set your DRC rules to (like where
    you have a via close to a wire of same net). I hope Cadsoft will do
    something to that, so we can see it in the check list.
    I have a drc to fill via-via (inc pads&smd) and polygonfill-via, but not
    wire-via. Would that help? It may need some tuning as it is only tested with
    my 16 layer HDI type II stackup.
    Olin wrote on Thu, 14 January 2010 13:25
    James Morrison wrote on Wed, 13 January 2010 22:05
    manufacture their board(s).  However, AC requires 10mil clearance from
    a drill to any other feature on an internal layer.
    Unless you're using very tight design rules, you won't run into this
    limitation.  For example, if you're using 8/8 rules, which any board
    house in the world can do, then the nearest copper not belonging to a via
    would be 16 mils away.  If you're using less than 5/5, then I guess you
    could bump into this problem.  Advanced circuits can do some pretty fine
    stuff, but probably not with the same process that requires 10mil
    clearance from the hole edge.
    I use 5/5 or even 4/4 space/trace on many boards.  Mostly due to BGA's.  So
    yes, it matters to me.
    James.
    manufacture their board(s).  However, AC requires 10mil clearance from a
    limitation.  For example, if you're using 8/8 rules, which any board house
    in the world can do, then the nearest copper not belonging to a via would
    be 16 mils away.  If you're using less than 5/5, then I guess you could
    bump into this problem.  Advanced circuits can do some pretty fine stuff,
    but probably not with the same process that requires 10mil clearance from
    the hole edge.
