EAGLE User Chat (English) ULP for embedding images  into ULP's
  • Subscribers 187 subscribers
  • Views 566 views
I wanted to embed icons/images into ULPs instead of having messy html links
or loose images lying around, so I decided to make this Base64 encoder that
helps creating the code needed. I want to share it with you of course image
Should work with all dialog objects supporting HTML
Tested with PNG,GIF and JPG, but probably work on others too (as long as
file extension equals "image/" html data format.
Happy New Year to you all!
ImgB64Enc.ulp.zip
    autodeskguest over 11 years ago in reply to autodeskguest
    "warrenbrayshaw"  skrev i nyhetsmeldingen: m8imjn$ukn$1@cheetah.cadsoft.de
    Great minds think in unison. This was exactly my thoughts this past couple
    of weeks.
    Great image Tell me if you are working on an ULP to generate symbols from
    pinlists too image
    Also works with .bmp.
    I guess we should recommend stay away from BMP purely because of size.  PNG
    is lossless and no disadvantages over BMP afaik.
    Now I just miss some html support in more dlg objects, like buttons and
    listview.
    links or loose images lying around, so I decided to make this Base64
    encoder that helps creating the code needed. I want to share it with you
    of course image Should work with all dialog objects supporting HTML
    file extension equals "image/<extension>" html data format.
    couple of weeks.
    I had to mend it in a few places as strings had wrapped.
    Congrats
    Warren
