EAGLE User Chat (English) GND on two layers
  • Subscribers 187 subscribers
  • Views 473 views
GND on two layers
LS,
Is there a thumbs rule connecting two layers.
On the bottom and on the top layer I have a GND polygon.
To reduce stray current I would like to connect these two using via's.
Regards
Harry
    The plane should carry a current of approx. 3A at 18V DC
    "Gary Gofstein" <nospam@use.forum.net> schreef in bericht
    news:hl1u5s$8mk$1@cheetah.cadsoft.de...
    No. You would need to know the distribution of the current for DC. For AC
    currents in the RF range you need to know the shape of the pulse and solve
    the wave equation to know where the current will flow and what skin depth
    it will flow in. Nobody does that.
    For "normal circuits", it's seldom an issue. How much current are we
    talking about here anyway? DC, audio or RF current?
    To get a comparison for DC currents you can look at trace temp rise vs
    size charts for ordinary traces. You will see that unless you use super
    thin "digital" traces, it's usually okay. I always use the biggest traces
    I can fit anyway. There's a ULP that calculates temperature rise on traces
    for DC currents; you'll see that your plane is likely to be much bigger
    than necessary. You don't need to know how many vias to add, because you
    should just add as many as you can to get the best performance. You can
    estimate the temperature rise of a via by thinking of it as  a wire,
    figure out the equivalent wire guage, consult a current vs temp rise site
    or chart to get the temp rise. You should specify your vias to be solder
    filled for best DC and thermal conductance. If you will never solder to
    them, you don't need thermals on vias (EAGLE default anyway). Actually,
    it's possible to tack solder a wire even on a via with no thermal, so it's
    rare to need a thermal on a via. All this applies only to DC currents,
    RF/pulse currents are a whole nother story...
    Oh yeah, if you are thinking that knowing the voltage drop is important,
    it may not be. If you plan on using that ground plane as a voltage
    reference you should just run parallel ground traces that don't carry
    current to anyplace that needs to know ground voltage (like an opamp
    input or voltage regulator). These are separate from the plane returning
    current to ground potential and generating voltage drops.
    AC currents in the RF range you need to know the shape of the pulse and
    solve the wave equation to know where the current will flow and what
    skin depth it will flow in. Nobody does that.
    traces I can fit anyway. There's a ULP that calculates temperature rise
    on traces for DC currents; you'll see that your plane is likely to be
    much bigger than necessary. You don't need to know how many vias to add,
    because you should just add as many as you can to get the best
    performance. You can estimate the temperature rise of a via by thinking
    of it as  a wire, figure out the equivalent wire guage, consult a
    current vs temp rise site or chart to get the temp rise. You should
    specify your vias to be solder filled for best DC and thermal
    conductance. If you will never solder to them, you don't need thermals
    on vias (EAGLE default anyway). Actually, it's possible to tack solder a
    wire even on a via with no thermal, so it's rare to need a thermal on a
    via. All this applies only to DC currents, RF/pulse currents are a whole
    nother story...
    Is there a package that one can calculate the voltage drop on a layer that
    uses a polygon with or without via's?
    news:hkvea1$h1m$1@cheetah.cadsoft.de...
    In general, if they are to transmit high current, heat or digital
    switching transients between the two ground conductors, you should place
    alot of them. If the conductors are to be AC, or thermally, isolated, only
    one. Not a simple topic, but most hobbyist circuits- doesn't really
    matter.
    only one. Not a simple topic, but most hobbyist circuits- doesn't really
    matter.
