EAGLE User Chat (English) How to import an existing design into a new one?
  • Subscribers 187 subscribers
  • Views 377 views
My board design has several circuits, one is a Zigbee 2.4 GHz
transceiver from TI.  TI recommends that I copy their reference design
exactly into my pcb.  They provide a Gerber file.  I see how to import a
complete design into a complete design but how do I do a complete design
into part of an existing design?
TIA
John Bachman, W1JGB
AnaTek Corporation
    I don't know of a tool that will read Gerber into EAGLE, though it
    should be possible to write ULP to do this. I would check the EAGLE
    website for such a tool, seems like something that has been done in the
    past. Maybe that's what you mean by import the complete design. If you
    have it in EAGLE, then you can probably use some merging or panelizing
    ULP to put them together.
    In the absence of that, I would try to edit the gerbers together, maybe
    there is such a gerber tool that can cut and paste gerber images on the
    web. They are just text files, but it may not be trivial to locate the
    imported section where you want it, as in , you may need to write a
    program to offset all the locations of each element as you merge the data.
