EAGLE User Chat (English) Work flow suggestions
  • Views 670 views
Hi all,
I'm not new to electronics, but new to Eagle. This is a hobby now, not a
profession anymore, and it's been awhile since I've really done any real
design (my career took me into physics/dynamics and away from electronics).
I'm using Eagle mostly to copy public domain circuits, maybe some
modifications, then build them.
I also bought B2 Spice. (I've tried a few simple schematics with some
frustration due to inconsistencies with Eagle library names versus the B2
library/model names. But I think that is more for the B2 forums...)
That said, I'd love some advice on work flow. Most/all of the circuits
which interest me are analog audio processing types; filters, oscillators,
amplifiers, etc. ending up in a modular synthesizer.
That now said, is it easier to build the schematic in Eagle then convert it
to B2 format and just deal with the missing models in B2 Spice? Or, is it
easier to build the circuit in B2 Spice then port it to Eagle? I've not
tried the B2 Spice to Eagle route yet as I'm still just trying to get
through the Eagle manual.
Any users of Eagle and B2 Spice out there who are willing to give me their
2 bits of advice?
David
    Gary Gofstein wrote on Wed, 24 February 2010 17:37
    well..if it's easy to port it to SPICE then you have the advantage that
    if you want to make a board, the schematic is already in EAGLE. that
    may
    deleted...
    unfortunately, i believe that the best way to get learn about the freq
    domain is to study it. use old books (like from the 60's) that don't
    rely on computers and DSP. learn how to use the s-plane. someday I will
    have time to do this properly, too image
    Thanks Gary. I think I agree. It makes sense to do the capture in Eagle,
    then port to B2 Spice. I will be doing less simulation that schematic
    capture so I think it's more efficient this way.
    For what it's worth, when I started getting back into electronics a year or
    so ago, I bought some new tools and I do have a good (not top of the line)
    dual trace scope with FFT.
    For context, my background includes graduate degrees in physics and
    bioengineering, and I took several EE courses as a senior in undergraduate
    school. I've done a lot of control system design and analysis so the "S"
    plane is (well, used to be) my friend :). I've designed and built
    instrumentation/data acquisition systems, and for the past several years,
    I've been analyzing dynamical systems and writing some dynamic simulation
    code. That said, I never did really learn analog design. I'm still
    convinced it's done in dark rooms with chicken bones and black magic image
    The modules are mostly pretty simple. A few op-amps, a couple of
    transistors, and the requisite capacitors and resistors. Even the most
    complicated ones typically fit with room to spare on a 160 X 100 mm board.
    So far, none are my own design and so their respective designers have done
    the breadboarding and confirmed their designs. There are just so many I'd
    like to look at and learn from but I'm disinclined to buy the parts and
    spend the time breadboarding them. I'm hoping I'll be able to get enough
    out of a decent simulation to satisfy my curiosity.
    I do appreciate the time you've taken to discuss this with me.
    David
    if you want to make a board, the schematic is already in EAGLE. that may
    not be such a big advantage if modules are small and easily copied from
    one schematic capture tool to another.
    again..i would skip SPICE and just play around with the circuit on a
    breadboard. to check things in SPICE I would just use circuit fragments
    - although maybe your modules are so simple that they are almost circuit
    fragments anyway. Really only useful for frequency domain analysis.
    If your oscilloscope has builtin FFT, you can often quickly see circuit
    response by exciting it with white noise. and if you can average the
    spectra ( as opposed to signal) on the scope or computer, you'll get
    decent response curves. if you are making an audio synth, that wng will
    be your first project anyway.
    Gary Gofstein wrote on Tue, 23 February 2010 15:28
    my advice if you are building analog circuits is not to use SPICE and
    this goes 10x if they are audio circuits. SPICE will not tell you
    whether your circuit picks up hum or radio stations or your cell phone.
    It won't let you know about common ground impedance that makes your
    circuit ring or distort. It usually doesn't tell you what it will sound
    like when your choice of opamp saturates, or nearly saturates.  It will
    not tell you whether you want a mica or ceramic or polypropylene
    capacitor. In fact, it usually won't tell you anything you don't
    already
    know. Your ears will tell all of these things though.
    SPICE is sometimes good for figuring out what function a filter does or
    how to modify that and basically for experimenting with parameters in
    ideal circuits...but it's no substitute for a real circuit. Audio
    circuits, unlike some other types of circuits, are easy to breadboard.
    Great advice Gary, and I've heard it from others. For me, I'm using Spice
    as more of a learning tool, like you said, figuring out what a filter is
    doing, and experimenting. As I said, I'm not doing too much original
    design, mostly as a tool to understand circuits others have designed and
    for experimenting with designs which already work and which I may or may
    not want to actually build. I want to take a schematic into Spice and probe
    it so I get an intuition for what signals are doing where, and for
    learning, and maybe to help trouble shoot when I stuff the wrong
    capacitator on the board image
    Would you recommend doing the schematic in Eagle, then porting it to B2
    Spice?
    Thanks for the reply.
    David
    capacitor. In fact, it usually won't tell you anything you don't already
