EAGLE User Chat (English) How to fix clearance errors due to polygons
  • Subscribers 187 subscribers
  • Views 450 views
I uploaded my design to the board house (AC Circuits) using their
manufacturing analysis.  It returned with more than 100 clearance
problems, all caused by the ground polygon being 4.776 mils away from a
signal track.  I have all of the clearances set to 5.00 mils minimum.
How can I fix this?
John Bachman, W1JGB
AnaTek Corporation
    autodeskguest over 16 years ago in reply to autodeskguest
    Gary Gofstein wrote on Mon, 22 March 2010 17:05
    and if no reason to have them close, i would just use 8. anyone can do
    8 these days...
    Yeah, that's what I do too.  I use 8/8 rules unless there is a good reason
    tighter spacing is needed.  Even if a board house can do better, you don't
    want to be pushing the limits.  8/8 is pretty universally safe nowadays.
    signal track. I have all of the clearances set to 5.00 mils minimum. How
    can I fix this?
    After posting I came up with a fix that seems to work. I changed the
    minimum clearance to 6 mils and ran RATSNEST again to recalc the
    polygons. The board house accepted that design without any clearance
    errors.
    yeah, this has happened before. 5mils seems rather tight to me anyways,
    even if they advertise they can hold that tolerance, do you really want
    ( need) them that close? 6 sounds better, and if no reason to have them
    close, i would just use 8. anyone can do 8 these days...
    can I fix this?
    errors.
    John Bachman, W1JGB
    AnaTek Corporation
