EAGLE User Chat (English) Disabling Right-Click Menus in v5.8.0
  • Replies 20 replies
  • Subscribers 187 subscribers
  • Views 2264 views
Is there a way to disable the right-click context menus in v5.8.0?  I have
just switched from v4.16, and have gotten used to being able to simply
right-click to perform actions on a group without the additional click in
this new context menu.  This makes accurately moving groups of parts
difficult, as the group snaps to where your mouse cursor is when you click
Move:Group in that menu.
Love EAGLE!  One of the best pieces of software I've ever used!
~Rod
    Am 30.04.2010 08:09, schrieb Tilmann Reh:
    Brett Holden schrieb:
      if they see fit to show me a "context" menu of undesired commands - even
    after I have expressly commanded GROUP>  MOVE (for instance instead), then
    they have wasted resources going in a direction that I do not want to go.
    I don't see the improvement, so maybe I'm not like everybody else.
    I also don't see any improvement, and I didn't call for the context
    menus. However, it really was persistently requested, so Cadsoft finally
    implemented it. As long as I can disable it, that's OK for me. image
    Tilmann
    P.S. Please do not top-post.
    Full Ack
    Gruß / regards
    Joern
    after I have expressly commanded GROUP > MOVE (for instance instead), then
    Tilmann
    Well, if Cadsoft wants to expend their resources on programming a drop down
    menu of connectors library parts to get displayed - even after I have moved
    to my capacitor library (just for instance),
    or,
    B
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:hrb9j9$b8o$2@cheetah.cadsoft.de...
    I hate those menus. Just like I hate how ver 5.8  wants to pan my view
    screen with key combinations that I counted on for something else.
    I wish that Cadsoft would see fit to make these "improvements" optional,
    instead of making them the default operation which needs to be corrected
    through some arcane "expert" tweak, if you liked the old way of doing
    things.
    Just because something is new or different does not necessarily mean it
    is
    an improvement.
    Eagle used to be something special to me but lately it has become a
    whirlwind of useless window dressing, forcing me to adapt to some new,
    undesired, program behavior each time I install an "update".
    Other people have requested exactly those features long enough to
    finally get them... Otherwise, Cadsoft would be blamed to not listen to
    the customer requests. You can't serve /all/ people best.
    At least EAGLE can be configured to behave the old way resp. to fit your
    personal taste.
    Tilmann
    things.
    Just because something is new or different does not necessarily mean it is
    an improvement.
    personal taste.
    Tilmann
    things.
    an improvement.
    "Rod Martinez" <diyermaker@yahoo.com> wrote in message
    news:hqj377$tf3$1@cheetah.cadsoft.de...
    ~Rod
    ~Rod
    I would like to add to Warren's comment, that the eaglerc.usr file can
    be modified through the EAGLE command line. Simply type the following:
    SET Option.ToggleCtrlForGroupSelectionAndContextMenu 1;
    That way you don't have to go looking for the file in the EAGLE folder
    of your C drive. I retract my former comment.
    Jorge Garcia
    Jorge Garcia wrote on Tue, 20 April 2010 16:04
    I have
    simply
    click in
    parts
    you click
    I know what you're talking about. I'm afraid you can't turn off the
    context menus. A way I have found to move objects precisely is to use
    the properties command. When you open the properties command you can
    see
    the exact coordinates at which the component is located. By modifying
    these coordinates you can very precisely locate your components.
    That's poppycock!  Warren had it right.  You can use the "set" command to
    change some of the low level behaviour like this one.  The first thing I do
    when I install EAGLE 5 is to do this to get the EAGLE 4 behaviour back for
    applying a function to a group.
    There is also one there to reset the cursor position when you have that
    case so you don't lose your position by using the menu.  But I prefer the
    EAGLE 4 method.  If I selected a group then I'm doing it to apply a
    function to that group.  You can use the Ctrl key to get the right-click
    menu back if you need it in that case.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    ~Rod
    Hi Rod,
    the properties command. When you open the properties command you can see
    Hope this helps.
    Jorge Garcia,
    Cadsoft Computer, Support Specialist
    From the manual  Options for Experts in Eaglerc>
    Group Selection
    Since the context menu function on the right mouse button interferes with
    the selection of groups, a group is now selected with Ctrl plus right mouse
    button. If you want to have the old method of selecting groups back, you can
    add the line
    Option.ToggleCtrlForGroupSelectionAndContextMenu = "1"
    to the file. This will allow selecting groups with the right mouse button
    only
    and require Ctrl plus right mouse button for context menus.
    Warren
    ~Rod
    I think the key may help.
