EAGLE User Chat (English) Disabling Right-Click Menus in v5.8.0
  • Replies 20 replies
  • Subscribers 187 subscribers
  • Views 2233 views
Is there a way to disable the right-click context menus in v5.8.0?  I have
just switched from v4.16, and have gotten used to being able to simply
right-click to perform actions on a group without the additional click in
this new context menu.  This makes accurately moving groups of parts
difficult, as the group snaps to where your mouse cursor is when you click
Move:Group in that menu.
Love EAGLE!  One of the best pieces of software I've ever used!
~Rod
    Gary Gofstein wrote on Mon, 03 May 2010 16:17
    I took it to mean disgusted disagreement.
    Yes, that was what I thought the first time I saw it too.  Eventually the
    intended meaning came thru from context.
    Quote:
    I agree that it is confusing, particularly when it occurs without
    explanation.
    Exactly.  Once again the lesson is don't use abbreviations unless you are
    very very sure they are understood as such by all of your audience.  If you
    don't, you'll be misunderstood and possibly look silly.
    The above is self-evident, but I am continually amazed by how many people
    still try to save a few 100ms by typing a shortform instead of spelling out
    what they mean.  "Agreed" is only 3 characters longer than "Ack", but has
    the advantage of actually meaning what you are trying to convey.
    On 5/2/2010 9:10 AM, Olin Lathrop wrote:
    Joern Paschedag wrote on Fri, 30 April 2010 04:50
    Full Ack
    I've seen this a lot here on the Eagle forums. Maybe it is some german
    thing, although I speak german reasonably well and that doesn't seem the
    case to me.
    Apparently you mean to express agreement. However, you are really only
    saying that you acknowledge the message (ACK is short for acknowledge, and
    a common abbreviation for communication protocol descriptions). Everyone
    else here really doesn't need to know whether you received a message or
    not. If you want to express agreement with a message, say so.
    I am not a German speaker and this is the only USENET group I frequent.
    I originally misunderstood ACK. "Ack" is the sound one makes in English
    to express impatient disagreement or more likely, disgust. In response
    to a controversial topic, I took it to mean disgusted disagreement.
    Never guessed it was jargon or abbreviation. This persisted for several
    months. I eventually figured it out, when more context was supplied. I
    agree that it is confusing, particularly when it occurs without explanation.
    Joern Paschedag wrote on Sun, 02 May 2010 18:26
    Is today your barking day again? No one is disturbed but you and
    besides
    no one is going to tell me what to use for an answer. This is going OT.
    So the discussion ends right here.
    Whoa, calm down, no need get all huffy.  If you had actually bothered to
    read what I wrote, you'd have seen that I was asking question about some
    usage I was not familiar with.
    I find how words and usage evolves interesting, although sometimes it's not
    really evolution but just misuse.  I have rarely seen this usage of ACK
    before, but noticed it a lot here.  Then I noticed it came only from
    germans, so it seemed possible that ACK somehow evolved a different meaning
    in recent german.  I see Tillman says it does mean acknowledge of the
    message, so my guess wasn't that far off.  Note that even acknowledgement
    of the message is quite different from agreement with it though, so I think
    there is yet more to this usage of ACK than Tillman describes.  I also
    disagree with him that it's universally common usenet jargon.  It may be
    common jargon amongst german speakers.
    You can of course say what you wish, although certain choices will be more
    widely understood than others.  Some may even have very different meaning
    than intended to part of the audience.  My suggestion is to use the
    conventions of the language you are writing in.
    Olin Lathrop schrieb:
    Tilmann Reh wrote on Thu, 29 April 2010 02:39
    Other people have requested exactly those features long enough to
    finally get them... Otherwise, Cadsoft would be blamed to not listen
    to the customer requests. You can't serve /all/ people best.
    I can understand why CadSoft has to add new features.  The point though is
    that all new features which change existing behavior should be made
    optional with the default being the old way.
    I tend to this viewpoint, too.
    OTOH, CadSoft probably makes (more) money with new customers than with
    the existing ones upgrading to the current versions. So it's reasonable
    to address these - eventually by making the UI more "standard windows
    like" (as with the implementation of the context menu, for example).
    As long as such changes are a) documented, and b) reversible by
    configuration, it doesn't really matter to me.
    Both has been the case up to now.
    Tilmann
    Full Ack
    case to me.
    This simply is usenet jargon. Just like IIRC, BTW, AFAIR and many other
    abbreviationes.
    Indeed it does mean "acknowledging" the message - but not its receipt,
    but its content.
    Tilmann
    Am 02.05.2010 19:34, schrieb Olin Lathrop:
    Joern Paschedag wrote on Sun, 02 May 2010 13:20
    "Ack" is very common in germany
    So now I'm really curios. What does it stand for then, and apparently it
    does not mean the english work "acknowledge"? Is that one of those words
    that came from english that then took on a life of its own? I'm not too
    good with technical german, but I understand computer-related words are a
    mish mash of real german, corrupted english, and outright english. For
    example (please correct me if I'm wrong) I belive "disk drive" is
    "speicher", whereas "computer" is "komputer" pronounced in a germanized
    way, and "bits" is just "bits". So where does "ack" fit in to all this and
    how did it evolve to apparently mean "agreement"?
    and was addressed to a german.
    But it was sent to everyone on the forum and it was written in english, so
    therefore must be judged as such.
    Is today your barking day again? No one is disturbed but you and besides
    Gruß / regards
    Joern
    Am 02.05.2010 18:10, schrieb Olin Lathrop:
    Full Ack
    case to me.
    "Ack" is very common in germany and was addressed to a german.
    Gruß / regards
    Joern
    Full Ack
    case to me.
    to
    optional with the default being the old way.  It seems every time I udpate
    Eagle I have to waste time figuring out why something that used to work
    doesn't work anymore, and usually not when I want to spend that time.  Let
    me decide when I want to investigate new features, and then if I want to
    enable them at all.
    I know the temptation of developers is to show off the shiny new "cool"
    features they just spent a lot of time implementing, but please please
    resist that temptation.  It drives us existing customers nuts.
