EAGLE User Chat (English) generate_3d_data
  • Replies 9 replies
  • Subscribers 187 subscribers
  • Views 1372 views
generate_3d_data
We are attempting justify purchasing Eagle to out managment,  I have
been trying to get a 3d model for use with solidworks using the
"generate_3d_data" ulp.  I am not yet working with any custom files only
the example files supplied with the install.  To this point every time I
run the ULP I get an error saying that there is no board-outline
defined.  At first I had to go and edit the ULP file to look at layer 20
instead of 50 but this makes no defferance.
Please help:)
Ryan
    Ryan B wrote:
    I am working on Win XP, Eagle version 5.9.
    I open one of the example PCB layouts (it dose not seem to matter which
    one).  Then when I run the "generate_3d_data.upl" I get the attached
    error dialog.
    with unmodified eagle example PCBs that won't work.
    1) you need to redraw the board outline in layer 50. The line width
    defines the board thickness.
    For cut-outs this will not work as described in the documentation (at
    least not with the ulp version I have). If you need cut-outs, define
    the board outline including cut-outs as a library part.
    2) for all parts you want to show up as 3 dimensional you need to
    modify the related library to contain the hight informations in layers
    57 (abovethe PCB) and 58 (below the PCB)
    Line width translates to hight as in layer 50 (1mic -> 0.001mm)
    Lorenz
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:hrafar$e3l$1@cheetah.cadsoft.de...
    Ryan
    Found this while looking for SolidWorks information.
    Go to this forum and read it. It will help you.
    https://forum.solidworks.com/thread/25452
    Locate within the posts the following file that contains modified ULPs
    that
    are likely to solve the use issues you are having with the original.
    https://forum.solidworks.com/servlet/JiveServlet/download/108393-38096/Results_temp.zip
    Ryan
    I thought I should warn you. I tried out these ULPs and alas you may not
    find instant success with them.
    Watch out for the spaces in the file names.
    They all use different layers
    (1) The file generate_3d_data_original.ulp uses layers
    50(Layer3dBoardDimension), 57(tLayer3Ddata) and 58(bLayer3Ddata) [Layer
    names defined withinULP]
    (2) The file generate_3d_data v08_PBF_Board only.ulp uses 20,(Dimension) 17
    (Vias) and 18(Pads)
    (3) The file generate_3d_data v08_PBF.ulp  uses 20(Dimension), 21(tPlace)
    and 22(bPlace)
    The last file needs closed shapes depicted on the placement layers. If just
    the corners of a device are depicted in tPlace/bPlace then un-closed polygon
    errors are reported.
    The output files are generated so have a go and see if Solidworks can digest
    them.
    Warren
    only
    I
    20
    Please help:)
    Ryan
    Yes I understand the limitations of the translated version, but I still
    need to try and get this working.
    Ryan
    Locate within the posts the following file that contains modified ULPs that
    Again, good luck.
    Warren
    Ryan B wrote:
    ................. using the
    only
    I
    20
    Ryan
    I have had a look into the ULP to see why I too get this message.
    Strange, but this ulp expects the board outline to be in an element/package.
    I built a  package  having only the board outline on layer 50,  added it to
    the board and then the ulp runs.
    Good Luck
    Warren
    On 4/28/2010 12:04 PM, Ryan B wrote:
    On 4/28/2010 9:30 AM, Lorenz wrote:
    Ryan B wrote:
    On 4/26/2010 1:40 AM, Lorenz wrote:
    Ryan B wrote:
    you've read
    ftp://ftp.cadsoft.de/eagle/userfiles/ulp/generate_3d_data_eng.pdf
    it's the abreviated translation of the original german description
    that comes with the ULP.
    I just compared both versions and it seems to me that there is nothing
    relevant missing in the english translation.
    So perhapse you should describe in more detail what problems you have.
    error dialog.
    is there a truly closed poly in that layer?
    Ryan B wrote:
    you've read
    error dialog.
    Ryan B wrote:
    you've read
    Lorenz
    Please help:)
    Ryan
    you've read
    Please help:)
    Ryan
    you've read
    Lorenz
