EAGLE User Chat (English) new library device is inaccessable
  • Subscribers 187 subscribers
  • Views 512 views
I just made one new device in version 5.8, adding it to an existing library
from v5.6. This is my first new device since updating to ver 5.8.
From the schematic editor, the new device does not show up in my "Add" parts
bin.
I have checked everything I can think of including making sure no illegal
characters or spaces are in the device or variant name. Still, I can't
access my new component.
I have done "update > xxx.lbr" through the schematic and PCB editors several
times -just in case- but that has not helped. I even started a new schematic
just to see if I could add the part there, but NO.
Strange, I can add the device to a schematic from the control panel tree
view. Still, the part will not appear through the schematic editor's "Add"
part.
Has anybody else seen this behavior or otherwise have some insight into what
is happening? I used to see this in a previous version when I tried to use a
space in my device or package name, but I have used no space here.
arrgh, help please
    Brett Holden wrote:
    Thanks, Tilman, Joerg. You two were on the right track. I see what's wrong.
    I incorrectly stated that I made a new device.
    In fact, all I did was make new package and then add a package variant to a
    device that was already in use.
    ... so "use *" should have had no affect. But It did. Each library is now
    listed twice.
    Yesterday, the schematic editor was listing libraries from a different
    directory than what I had specified, and not listing any libraries from what
    I did specify.
    I KNEW that, because I could read the path beside the library name, but I
    was too tired to know what to do about it.
    I will delete the incorrect libraries one by one and try to figure out how
    they got there some other time.
    No, wait... WHAT happened to the "Drop" library box in the Add part window??
    What did it do? Disappeared? Normally you highlight a library you don't
    want to see during the current session, click "Drop", and it vanishes
    from the selection screen. "Use *" will pop them all back in if you
    later change your mind.
    BTW, please respond below the text. That makes it much easier to follow
    for others in case a thread gets a bit longer.
    Regards, Joerg
    listed twice.
    I did specify.
    B
    "Joerg" <notthisjoergsch@removethispacbell.net> wrote in message
    news:hrcdpa$nl5$1@cheetah.cadsoft.de...
    library from v5.6. This is my first new device since updating to ver 5.8.
    parts bin.
    several times -just in case- but that has not helped. I even started a
    new schematic just to see if I could add the part there, but NO.
    "Add" part.
    what is happening? I used to see this in a previous version when I tried
    to use a space in my device or package name, but I have used no space
    here.
    arrgh, help please
    Try writing this into the command line:
    use *
    Don't forget the blank space. Hit enter and see if it works now.
    Regards, Joerg
    bin.
    part.
    arrgh, help please
    use *
    Regards, Joerg
    bin.
    part.
    Is the library "in use"?
    Tilmann
