EAGLE User Chat (English) Harddrive and cdrom drive power connector.
  • Subscribers 187 subscribers
  • Views 672 views
Hi all.
From past experience, I have learned that if I can not google the
problem, it does not exists.
Problem:
I would like to use a standard 5.25" bay power connector, the types on
IDE CD/HD Drives, on my pcb.
I have been unable to find the right name for it.
This is the wire-part of it:
http://en.wikipedia.org/wiki/Molex_connector#Disk_drive_connector_.28Molex_8981_Series_Power_Connector.29
it says it should be a molex 8981 series connector.
This is another page, showing the same connector:
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
It says it is from the 1-48* series by AMP.
I have had no luck in finding any of them in eagle lbr's, but nor have I
found anyone else *** about the problem... So what am I doing wrong?
/Jan Rasmussen - not using eagle as much as he should.
    GoWarren Brayshaw wrote:
    "Jan Rasmussen" wrotee
    Problem:
    Correction to second PDF link for verticle version
    Try Eagle Library:
    con-thomas-betts
    9090-4R
    9090-4V
    http://en.alexconn.tw/rt/database/pdf/9090-04R.pdf
    http://en.alexconn.tw/rt/database/pdf/9090-04V.pdf
    Good find Warren!  ....and it looks like its 200mil pitch.
    jim
    Problem:
    Try Eagle Library:
    con-thomas-betts
    9090-4R
    9090-4V
    "Jan Rasmussen" <donotsp@mme.no> wrote in message
    news:hugnru$6fa$1@cheetah.cadsoft.de...
    Problem:
    Try Eagle Library:
    con-thomas-betts
    9090-4R
    9090-4V
    or
    con-amp
    FLOPPY-4
    Den 06-06-2010 21:11, Jim Littlefield skrev:
    http://www.edaboard.com/ftopic309290.html
    Has a bunch of links...maybe one is what you are looking for? I did not
    find an obvious match in the Eagle libs...buts its only a 4 contact part
    so should not be hard to make your own.
    Yes I know, and by the looks of it, it would be more safe to get an
    connector and measure it, before making the layout, as there seams to be
    some confusion as there where it is 0.156" or 0.2" and so on.
    Was just hoping that Eagle had a component ready, but then again, what
    are the chances that the plug I get hold of, fits that image
    /Jan Rasmussen
    Jan Rasmussen wrote:
    Hi all.
    Problem:
    not find an obvious match in the Eagle libs...buts its only a 4 contact
    part so should not be hard to make your own.
    jim
