EAGLE User Chat (English) Creating a board from one schematic of a project - Content for all schematics seen on board layout
  • Replies 9 replies
  • Subscribers 189 subscribers
  • Views 1313 views
junkyarddog
junkyarddog over 10 years ago
I created my first project. It has several boards that interconnect. So, to make it easier, I created a separate schematic for each board.
When I transitioned to making the first board, all of the components for all of the schematics, including the rats nest interconnecting lines, are in the collage to the left of the layout box.
Is there a way to limit the components that are brought over to the board layout, to the components only in the mating schematic?
A few lucky breaks are that each board's component count is low, not too much use of the same component on multiple boards, and that the interconnecting lines don't cross from one schematic to another. Bringing all of the components for one board in to the layout block
I tried looking for a preference setting and other tips to explain how this flows. I've had no luck so far. Any help is appreciated.
    0 autodeskguest over 10 years ago in reply to dukepro
    I believe 6.0 introduced use of the host OS's cut-and-paste buffer.
    Maybe it was 7.0.  Jorge would know for certain.
    That was a long awaited feature that brought a grin of appreciation to
    my face when I read about it.
         - Chuck
    Hi Chuck,
    You care correct it came in quietly in the V6 family of releases.
    Another possible solution to complement Rachael's response is that you
    could use the import from functionality to import exisiting designs into
    new ones, this has the advantage of maintaining the layout(if it exists)
    and consistency.
    So you could open a new blank schematic, import the old one and repeat
    for as many sheets as you have.
    Best Regards,
    Jorge Garcia
  • dukepro
    0 dukepro over 10 years ago in reply to autodeskguest
    On 11/23/2015 04:24 AM, Rachael wrote:
    Morten Leikvoll wrote on Mon, 23 November 2015 08:42
    Two instancec of Eagle does not copy across afaik (unless its a brand
    new feature), but you can group copy, open/create a new project, then
    paste. This needs to happen from the same Eagle instance.
    Yes it does, I just tried it again just to make sure. It's not a new
    feature as far as I am aware, it's just not completely obvious that it
    should work this way.
    1. Open up two copies of eagle.
    2. In one instance open your source schematic.
    3. In the second open your destination schematic.
    4. In the source schematic group select the items to be copied.
    5. Type 'cut <Enter>'.
    6. Right click on a part to be copied, select 'Cut Group' (Note this does
    NOT actually cut).
    7. In the destination schematic type 'paste <Enter>'.
    8. Move mouse to position the items to be pasted to the right place and
    then left click.
    Best Regards,
    Rachael
        - Chuck
    0 autodeskguest over 10 years ago in reply to autodeskguest
    5. Type 'cut '.
    then left click.
    Best Regards,
    Rachael
    On 20.11.2015 23:20, Rachael wrote:
    Hi Stephen,
    You can  do it with the group select, cut, paste group commands with two
    copies of Eagle open but it's probably not the quickest way. It might be
    simplest to make four more copies of your current schematic and then just
    open them in turn and delete the additional schematic sheets from each of
    them so you end up with each schematic sheet in their own file.
    0 autodeskguest over 10 years ago in reply to junkyarddog
    Hi Stephen,
    You're welcome. Good luck with your project!
    Best Regards,
    Rachael
  • junkyarddog
    0 junkyarddog over 10 years ago in reply to autodeskguest
    Rachael,
    Thanks for your help! I think copying the file, and editing out the extra, would be easier.
    Hi Stephen,
    Best Regards,
    Rachael
  • junkyarddog
    I have 5 sheets within one .sch file. I take it that this does not create 5 sub-schematics under one file.
    So, now I need to create a new .sch file for each of the sheets created. Will I have to recreate each of the new drawings from scratch? Or, is there an easier cut-and-paste?
    Hi Stephen,
    When you say you created a separate schematic for each board, how did you
    go about doing this? Do you have separate .sch files for each schematic or
    have you just created additional pages from within a single .sch file? It
    sounds to me like you may have done the latter. Each separate board will
    have it's own .brd file and there must be a corresponding .sch file.
    Best Regards,
    Rachael
