EAGLE User Chat (English) Simple question about editing pads
  • Answers 2 answers
  • Subscribers 187 subscribers
  • Views 724 views
  • pad
trinewton
trinewton over 10 years ago
I've been trying to edit the spacing/position of the pads on this example .brd file-
http://www.instructables.com/files/orig/FG0/FRGD/I4PHX5J0/FG0FRGDI4PHX5J0.brd
And though I have accidentally modified the traces plenty of times, I have no way to modify the pads in the center.
So my question is- how can I edit, and more specifically, redimension and move already existing pads in a board file?
    Am 29.05.2016 um 06:36 schrieb Rohan Misra:
    https://www.element14.com/community/message/198221
    Your parts (devices) in the centre are BLK-MD-SPK-B with a package of
    the same name in a library (same name). (I don't know what is is
    supposed to be)
    Devices one cannot  change in schematic or board. They must be edited in
    the library, or one must create a new device that fits the suits.
    Also a package has a body and a name/value. just check a package in an
    eagle library to see what is necessary to make a correct device.
    Joern Paschedag
    Moving and editing pads that are just pads, placed on the board as just
    pads, is easy. But that's not what you have. You have a board with two
    SOIC-like devices placed on it. They're probably ICs that exist as such
    in the schematic. This is, of course, the RIGHT way to do it, and it's
    your question that's fundamentally wrong.
    I'll assume, for the sake of an example, that what you have are buffer
    ICs that are available in SOIC, but that you now want to fit the TSSOP
    versions. You're looking at this as "so I need smaller pads, closer
    together". That's WRONG. What you need is... TSSOP packages. So the way
    you do this, and it's really obvious once you know, is to "CHANGE
    PACKAGE" the ICs. Either enter that on the command line or click the
    spanner icon and select PACKAGE from the menu. Then click on the little
    origin cross in the middle of the IC. You will be offered all the
    available packages for that device. Select TSSOP.
