EAGLE User Chat (English) Re: Library for SOIC
  • Views 338 views
I'm trying out the freeware version of this software. Trying something very simple to get started.
Can't seem to be able to add a simple SOIC package to my schematic. Did the search thing
after clicking "ADD." Are there some hidden libraires for this simple stuff? I was able to see
this package while in the layout editor. That's not gonna help.
Thanks in advance!
    something very simple to get started. Can't seem to be able to add a
    simple SOIC package to my schematic. Did the search thing after
    stuff? I was able to see this package while in the layout editor.
    Adding a package to a schematic doesn't make any sense.
    You add a device there, which consists of a symbol for the schematic, a
    package for the board, and the (hopefully) correct connections between
    them. Packages are only for the board.
    I strongly recommend working through the tutorial - especially if you're
    new to PCB CAD.
    Tilmann
    Thanks in advance!
    Maybe you have not "USE"D all the libraries.   In the control panel
    window the library should appear with a green circle next to the
    filename if it is used in the design.
    Jim
