EAGLE User Chat (English) Create package from autocad 2012 to eagle 5.11.0
  • Views 592 views
Greating for all
I have a problem. I made a package of an integrated circuit in autocad 2012.
Here is the package (every color represent one layer).                http://dl.dropbox.com/u/37984244/fotos%20foros/package_autocad.png
I use DXF-Eagle script converter 2.2.3.
Here is the configuration         http://dl.dropbox.com/u/37984244/fotos%20foros/converter.png
Here is the result inside eagle             http://dl.dropbox.com/u/37984244/fotos%20foros/package_eagle.png
My problem is that I need that the green feet appear fill in eagle. but like you see, eagle only take that package like a WIRE!!!!, not like  a SMD feet.
Thanks for your help. If a I the find the answer I'll tell you here.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Am 18.12.2011 14:20, schrieb gorth kill:
    Hi Warren
    Thanks for your help. My interest is too be able to plot a milimetric package. I need extremely precision.
    > That's bacause I used autocad.
    However, I just cry out the way to make a confortable trace. if  you could recommend me a way to do that,
    > would be great for me... Thanks a lot.
    Why do not use
    RUN make-symbol-device-package-bsdl.ulp
    You can create a package with the package option.
    Please read also
    ..\eagle..\doc\make-symbol-device-package-bsdl-2011-en.pdf
    Alfred Zaffran
                                 Web:   <www.cadsoft.de>
    Geschäftsführer: Thomas Liratsch, Dipl.-Ing. Klaus Schmidinger
    EAGLE V6 availabe now!
    Warrem. Thank you so much.... I don't know what happened with me, but when I tried to fit the grid, eagle never showed it. but with your reflection, all took sense. thanks!!!!!!!!!
    gorth kill wrote:
    Hi Warren
    package. I need extremely precision. That's bacause I used autocad.
    could recommend me a way to do that, would be great for me... Thanks
    a lot.
    Eagle can represent your package with a resolution (0.1 micon with v5) far
    finer than a board house can manufacture so there is no need to use autocad.
    Ensure you have learned how to create library parts by doing the tutorials
    that are included with Eagle and found in many places on the intenet.
    Then create the package you need where  it is  a matter of choosing mm/inch
    and a grid appropriate to the scale of your device as determined using it's
    datasheet.
    What is the name of the package you are trying to make? I feel sure it will
    already exist in the Eagle libraries.
    Warren
    news.cadsoft.de
    Hi Warren
    Thanks for your help. My interest is too be able to plot a milimetric package. I need extremely precision. That's bacause I used autocad.
    However, I just cry out the way to make a confortable trace. if  you could recommend me a way to do that, would be great for me... Thanks a lot.
    gorth kill wrote:
    Greating for all
    autocad 2012.
    like a SMD feet.
    Hi
    You should direct your questions to Falk Stricker from who you obtained the
    ULP you are using to DXF toEagle. The ULP will have features and limitations
    and he as the writer will know the answers.
    The SMD pad shapes you are attempting to replicate are not be possible with
    v5 without DRC errors, which you could manually approve.
    Unless the exercise is to evaluate a DXF to Eagle conversion I would simply
    find that package in the encluded libraries (ref-packages.lbr), verify its
    sizing and use that.
    HTH
    Warren
    news.cadsoft.de
