EAGLE User Chat (English) EAGLE ulp generates wrong scale -- how to fix?
  • Views 1461 views
  • eagle
  • ulp
  • pcb
  • cnc
  • diy
  • mill
I'm trying to do isolation milling circuit board prototyping using Eagle lite version 6.0.0. This is the first version of Eagle I've used, so I'm a newbie!
To generate the mill control file, I'm using a script called fablab-mill-n-drill.ulp from here: http://fablab.marcboon.com/pcb/step2.html
Actual script: http://fablab.marcboon.com/pcb/fablab-mill-n-drill.ulp
Unfortunately, when I run this script, it generates the outlines in a very small scale in the lower-left corner of the board. I'm using the "singlesided" PCB from examples.
Image attached. The purple thing in the lower left is the generated traces; zoom image also included.
So, my guess is that the way scale in generating outlines works has changed between when this script was created in 2008, and version 6 in 2011.
I'm a software developer by trade, but have never used Eagle or the ULP language before. If I know how to properly compensate for scale, I could probably hack it into the program. But where do I look to figure out what the right scale should be, or how otherwise to fix this script?
Any suggestions or pointers more specific than "it's somewhere in the manual" would beappreciated!
  • kataze
    0 kataze over 13 years ago
    I know I'm like a year late here, but just in case another lab has the same problem and comes across this thread like I did:
    Change line 196 in fablab-mill-n-drill.ulp to read:
        eta         = 0.000003125,         // Eagle resolution in mm
    this will allow the script to cope with the change in internal resolution.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Am 07.01.2012 03:49, schrieb Marcus Dobeck:
    I'm having the exact same problem, using the latest version of Eagle. I just signed up here so I could subscribe to this. No idea how to fix it.
    Maybe it helps to read the "update_eng" in the doc directory of your
    eagle installation and search for  "Increased internal resolution:" .
    I don't know if this change in the internal resolution affects your problem.
    Joern Paschedag
