EAGLE User Chat (English) Library with VTI SCA100T Part?
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 968 views
  • vti
  • mems
  • sca100t
mamikee
mamikee over 14 years ago
I'm looking for a library file that includes the VTI  SCA100T-D02 inclinometer chip.  The data sheets don't even state which package it is.  It is a MEMS part.
I have designed my own parts using Eagle but aren't very good at it so I thought I would start here.
Mike Berry, Colorado
  • mamikee
    0 mamikee over 14 years ago in reply to e14 Contributor
    I'm in business, thanks!  You soon are overwhelmed on projects if you have to spend time on every little piece.  Imagine building a house if the first thing you had to do is build a hammer.
    mcb
    0 e14 Contributor over 14 years ago in reply to mamikee
    Am 23.01.2012 16:05, schrieb Mike Berry:
    I see no attached file but then I'm new to this.  My email is mcb theATthing ironxfer dt com if that works.  mcb
    The file is attached in Warren Brayshaw. Unfortunately the link between
    element14 and the other groups does not work correctly. If you don't
    want the newsgroup check at eagle central
    ca.http://www.eaglecentral.ca/forums/
    Joern Paschedag
  • mamikee
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Am 22.01.2012 20:56, schrieb Warren Brayshaw:
    The Sparkfun v5 libraries have the SCA1000 device that looks to be exactly
    what you need.
    I have extracted it and attached it here to make it simple for you. It will
    likely convert to v6 if you use it.
    You need to check to your satisfaction that it is exactly what you require
    and the footprint is accurate.
    Library devices do not get much simpler than this. Do the Sparkfun tutorial
    on creating library parts and you will never have to ask for a part again.
    HTH
    Warren
    Watch out for sparkfun libraries. They contain tons of additional layers
    which can spoil your libraries if just integrate the device. One can see
    the layers after using "set used_layers all"(Enter) in the command line.
    Use this command in package & device.
    Joern Paschedag
    what you need.
    HTH
    Warren
  • mamikee
    I downloaded the SparkFun Eagle libraries for Eagle 6.0.  In the "Sparkfun-Sensors.lib" file is a VTI section with the single SCA300 part in it.
    What am I missing?  Again I'm looking for the SCA100T part.  Any URL links would help.  Many thanks in advance.
    mcb
    Am 21.01.2012 19:52, schrieb Mike Berry:
    Section 3.2 of datasheet contains the footprint & measurements.
    IMO sparkfun has a eagle library including this device.
    Joern Paschedag
