EAGLE User Chat (English) Optimizing drillholes
  • Replies 8 replies
  • Subscribers 190 subscribers
  • Views 929 views
  • eagle
  • layout
  • pcb
Wolfskammer04
Wolfskammer04 over 14 years ago
I generated the Gerber files and found in the *.dri file that I have two drills with  0.0374inch (T03 0.0374inch 2). In the *.drd file I found them with this parameters:
T03
X10260Y24158
X10260Y26158
how can I found them in the board. What type of measuring unit is: X10260?
I want to change them to 0.0400inch.
Roland
  • Wolfskammer04
    0 Wolfskammer04 over 14 years ago in reply to e14 Contributor
    Many thanks, that works good!
    Roland
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Warren Brayshaw wrote:
    Wolfskammer04 wrote:
    >> Hi,
    >> I tried to do it that way but I did not find the maching holes. I
    >> know from a webcast that all measures in the gerber files base on
    >> inches except someone set it definitly to metric measures. So I
    >> swiched from one setting to the next hoping to find the maching
    >> values but I did not. It also seems to me that eagle inside uses a
    >> better accuracy as actually is used in the gerber files. Am I right?
    >> I guess I have build a simple project with only one hole to get the
    >> secrets out of the files.
    Let Eagle do all the hard work for you
    In the Board Editor: Options> Set>Drill tab>Set
    That will give you unique drill diameter symbols.
    Then run the ULP drill-legend.ulp which places a drill legend next to
    your design.
    Finally, display the Drill layer and any others that help and locate
    the two holes with the diameter of interest
    HTH
    Warren
    news.cadsoft.de
    OK a I missed a point
    There is a new layer named (144)  Drill Legend that has the symbols so turn
    off the regular Drill layer
    Note the legend is ADDED as a package
    Warren
    news.cadsoft.de
  • Wolfskammer04
    0 Wolfskammer04 over 14 years ago in reply to robotonics
    Yes I did it and using this aaproach I could find such things like unwanted e.g. burried vias because they come from different files. But this way there is no possibility to determine between small and larger holes. That would be mice of course. The values of the drill files look like integer values. There are no decimal delimiters visible so there must be a coherency between the real values used by eagle and the used accuracy in the drill files.
    0 e14 Contributor over 14 years ago in reply to Wolfskammer04
    Then run the ULP drill-legend.ulp which places a drill legend next to your
    design.
    Finally, display the Drill layer and any others that help and locate the two
    HTH
    Warren
    news.cadsoft.de
  • robotonics
    0 robotonics over 14 years ago in reply to Wolfskammer04
    Hi
    Oh well, worth a try! I am not sure about the accuracy issue, perhaps someone else will chime in on that.
    Have you tried a more low tech approach, perhaps you could preview the drill locations with a gerber viewer, and overlay on your component layout?
  • Wolfskammer04
    I tried to do it that way but I did not find the maching holes. I know from a webcast that all measures in the gerber files base on inches except someone set it definitly to metric measures. So I swiched from one setting to the next hoping to find the maching values but I did not. It also seems to me that eagle inside uses a better accuracy as actually is used in the gerber files. Am I right? I guess I have build a simple project with only one hole to get the secrets out of the files.
  • robotonics
    Hi
    Im guessing you have got X and Y axis coords here in whatever units your grid is set to. If so, you could then move your cursor on the layout, and from the coords box (top left) you can read out the position that your two drills are at, you will find the pads and change the drill sizes?
    For example if units are in millimetres then from the cross (origin) on the pcb layout window your first drill would be at X = 102.60mm and Y at 241.58mm.
    Just an idea!
    T03
    X10260Y24158
    X10260Y26158
    Roland
    Hi Roland,
    The X10260Y24158 is your X and Y coordinates from the origin.
    There are only 2 of them so use the change command on those locations.
    -D
