EAGLE User Chat (English) Group explicit Pins in Symbol
  • Subscribers 187 subscribers
  • Views 460 views
Hi there,
i'm trying to GROUP several PINs in my symbol by entering their name into the consol. For Example: -- SHOW TDO/TDO/ nCSO/DATA4/ -- shows my two PINS TDO/TDO/ and nCSO/DATA4/. I want to reach nearly the same, only with the GROUP-Order.
Is it possible to wirte something like -- GROUP TDO/TDO/ nCSO/DATA4/ -- into my consol, so that i can easily GROUP these two PINS?
I've got a symbol with 898 PINS.. and i'm doing quite hard to find several pins..
    0 autodeskguest over 13 years ago
    mm mm wrote:
    Hi there,
    several pins..
    http://www.element14.com/community/message/77775#77775
    Not exactly what you have asked but is the SHOW command that draws a box
    around the found objects of use?
    SHOW @ pin1 pin2
    With a large FPGA it was easy to find the pins as they will always be in the
    corners of the box.
    How were you going to use the GROUP command if you could gather multple pins
    into the group?
    Warren
    news.cadsoft.de
    Am 26.05.2013 23:29, schrieb mm mm:
    Hi there,
    several pins..
    DISPLAY layer 93 Pins.
    GROUP all your pins and use CHANGE VISIBLE BOTH and right click into the
    selected group. This way you can see the pin names and the directions
    (in, out, nc etc.) Help pin (visible).
    Joern Paschedag
