EAGLE User Chat (English) invoke hidden reference pin?
  • Views 705 views
I'm having issues invoking a hidden reference pin on a shunt regulator in eagle. the case style is SOT-23-3.
Every time I try to invoke it I get the error that the "part has only 1 gate"
Any help would be greatly appreciated!!
    0 e14 Contributor over 12 years ago in reply to autodeskguest
    I wish I had waited for your reply. I ended up essentially creating a new device and adding the pin in myself image your way is a lot cleaner.
    The longer I work with eagle the more  I realize the importance of every character in a name...
    Thank you for the help! Definitely good knowing the reasoning behind it.
    0 autodeskguest over 12 years ago in reply to e14 Contributor
    1 gate"
    On 16/02/14 15:20, ele_fox wrote:
    Hi Warren it's in the Texas library part LM4041 package DBZ_R-PDSO-G3
    Take a closer look at the library. It's not done like that.
    The "hidden reference pin" is provided by using the LM4041*I component
    instead of the LM4041. This is because the adjustable (3-pin) device is
    a fundamentally different device from the fixed 1.2V (2-pin) one,
    regardless of whether TI decided to give them suspiciously similar names.
    Eagle does not support components with variable numbers of schematic
    pins so they must be treated as different devices.
    Cass
    gate"
    Please attach the library file or describe where it is so we can
    evaluate it.
    Cheers
    Warren
