EAGLE User Chat (English) Info
  • Views 516 views
Info
I am having a problem getting my wires to connect to my parts on the eagle cadsoft software. Is there a possible solution to this problem?
  • dukepro
    0 dukepro over 12 years ago
    Make sure your schematic grid is set to 0.1 inches.  Also make sure each
    component symbol is on-grid.  You can do this by starting the MOVE
    command, then do a Control-Click on the symbol.
    As Joern suggested, use the NET command in lieu of the WIRE command.
    From the pull-down menu, it's Draw=>Net.  There's an icon along the left
    side for this as well.  A mouse-over will tell you what each icon does.
    If you start the MOVE command and grab a symbol, the connected nets will
    rubber-band as you move the symbol around.  ESC will abort the move and
    return the symbol to it's original location.
    HTH,
        - Chuck
    0 autodeskguest over 12 years ago
    Am 20.03.2014 13:58, schrieb Chevaughn Fraser:
    http://www.element14.com/community/message/106863
    Not enough details. First of all use nets.
    Are your pins on grid?
    Joern Paschedag
