EAGLE User Chat (English) >$1000 for a simple 8"x8" PCB???
  • Replies 12 replies
  • Subscribers 183 subscribers
  • Views 1451 views
  • eagle
  • pcb
I want to make a simple PCB, so I'm looking at Eagle as it seems to be what other hobbiests use.
The board is 8" x 8", and will have only a few LEDs and chip resistors on it. I don't need multiple layers, libraries, autorouting, or even drilled holes. I could make the PCB by hand with a utility knife, but I thought using a PCB program would be neater and cause less hand stress. BUT it seems the Eagle program is more than $1000 to do this! Do other hobbiests really spend this? (I was hoping for free...)
My question: Is there another program out there cheaper, Eagle just seems unreasonably priced.
  • Problemchild
    Problemchild over 11 years ago in reply to johnbeetem +1
    Indeed John 1 PCB is basically the same as 10 from a small run organisation which is only marginally less than 100 off. um PCBPOOL wants around £100 for a 1 off 2 layer 200mmx200mm i.e. 8" on side!
  • vsluiter
    vsluiter over 11 years ago +1
    Hi Steve, At work I'm using a design package that costs 1k anually for maintenance... It does however work very well, with very little frustration during routing. For private projects I used to work with…
  • rea5245
    rea5245 over 11 years ago +1
    Steve, I've assembled a list of free PCB CAD software. Since some of the packages are crippled versions of commercial software, I include details of what the limitations are. You can see the list at http…
  • rea5245
    0 rea5245 over 11 years ago
    Steve, I've assembled a list of free PCB CAD software. Since some of the packages are crippled versions of commercial software, I include details of what the limitations are. You can see the list at http://PCBShopper.com/cad.
    When it comes time to manufacture your board, check out PCBShopper's main page (http://PCBShopper.com). There, you can enter in the size of your board, the number of layers, and the quantity, and you'll get a list of prices from 14 different manufacturers (as of May 2014 - I'll be adding more later).
    PCBShopper is not affiliated with any manufacturers. I'm just a hobbyist who thought it would be a good tool to provide for others.
    - Bob
    0 mcb1 over 9 years ago in reply to rea5245
    rea5245
    Bob.
    That site is a great resource and using sensible criteria.
